Problem with BOE-BOT servomotors
Dear all,
I have a problem with the servomotors of my Boe Bot.
I explain my issue;
I tryied to test my servomotors with this command:
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
when I test one servomotor with this command "PULSOUT 13, 650 or 850" it works! but when I try both servomotors together, one of them turns only in one way even if I change the pulses (650 clockwise, 850 counterclockwise)
I hope you can help me
I explain my issue;
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
Also, make sure all of your batteries are brand new. Used batteries could cause a Stamp reset when both servos start up at full speed.
