Problem with BOE-BOT servomotors — Parallax Forums
thomas_pittinthomas_pittin Posts: 29
edited 2014-01-07 13:55 in Robotics
Dear all,
I have a problem with the servomotors of my Boe Bot.
I explain my issue;
I tryied to test my servomotors with this command:
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
when I test one servomotor with this command "PULSOUT 13, 650 or 850" it works! but when I try both servomotors together, one of them turns only in one way even if I change the pulses (650 clockwise, 850 counterclockwise)
I hope you can help me
    If your servos don't stop 100% using a constant stream of PULSOUT 750/PAUSE 20's, then they are not centered. There is a trimpot adjustment screw on each servo which allows you to manually adjust that.
    Also, make sure all of your batteries are brand new. Used batteries could cause a Stamp reset when both servos start up at full speed.
