Propeller on a breadboard
I just tried building the circuit on page 17 of the Propeller manual and the PC is not able to detect the Propeller chip. In addition to what is pictured on page 17, I also connected a bypass capacitor between pins 9 and 12 of the Propeller chip. Do I also need a bypass capacitor between pins 29 and 32? Is there anything else I need to add beyond what is shown on page 17? I'm guessing that I may also need a bypass capacitor between pins 4 and 8 of the EEPROM. Would that capacitor being missing cause the problem with detecting the Propeller?
So, if the Prop runs the flashing program the "PropPlug" must have been detected.
Are you using a terminal program such as "TeraTerm" like I do?
Instead of the PropTool internal terminal?
The problem may be that the external terminals don't automatically disconnect when you switch back to the PropTool. This causes PropTool to be unable to detect the Prop. Stands to reason because the terminal is still connected.
The solution is to "Disconnect" the terminal when going to PropTool, PropGCC, BST, or other Prop programmer.
When done just have the terminal reconnect.
BTW, the internal PropTerminal does automatically connect and disconnect. Although PropTerminal is not nearly as sophisticated as the VT-100 terminal emulators. Don't get me wrong, PropTerminal is a nice simple stripped down terminal program.
Duane J
David
http://www.youtube.com/watch?v=q_Q5s9AhCR0
Start watching a 3:00..
Jim
