Crystal oscillator questions
JDat
Hello!
Newbie question.
Why Propeller don't need 18-22 pF capacitors for external crystal oscillator? Usually Pierce oscillator (used on most MCUs) need external capacitors. How this is solved on Propeller 1 (and maybe Propeller2)? Did I missed something in datasheet?
Newbie question.
http://www.parallaxsemiconductor.com/sites/default/files/parallax/Propeller-P8X32A-Datasheet-v1.4.0_1.pdf
You can check the oscillator margin with a series resistor on the crystal, and you may want to check temperature extremes.
Osc startup is usually 'harder' than run, so cycle the power at each test.
If precision matters, (ppm levels) you may need some additional external C, as well as the on-chip C's, in order to match the Xtal's test/Cal C value.
