Crystal oscillator questions — Parallax Forums
JDatJDat Posts: 103
edited 2014-01-02 13:43 in Propeller 1
Hello!
Newbie question.
Why Propeller don't need 18-22 pF capacitors for external crystal oscillator? Usually Pierce oscillator (used on most MCUs) need external capacitors. How this is solved on Propeller 1 (and maybe Propeller2)? Did I missed something in datasheet?
  • LeonLeon Posts: 7,620
    edited 2014-01-02 12:58
    The chip includes the capacitors, it's in the documentation.
  • JDatJDat Posts: 103
    edited 2014-01-02 13:01
    Can You, please, give me additional information regarding this? Seems that I am little bit blind after beer :D and can not find information in datasheet.
    edited 2014-01-02 13:04
    Page 4 of the datasheet says that no Cs are needed. Page 25 specifies the input capacitance as 6 pF.
    edited 2014-01-02 13:10
    Will that be sufficient to launch propeller into space (on cubesat)?
    edited 2014-01-02 13:14
    Will what be sufficient?
    edited 2014-01-02 13:19
    Thank You very much for this information!
  • jmgjmg Posts: 15,199
    JDat wrote: »
    Will this be sufficient to launch propeller into space (on cubesat)?
    You can check the oscillator margin with a series resistor on the crystal, and you may want to check temperature extremes.
    Osc startup is usually 'harder' than run, so cycle the power at each test.
    If precision matters, (ppm levels) you may need some additional external C, as well as the on-chip C's, in order to match the Xtal's test/Cal C value.
