help with mini-voltmeter pin out
davejames
Hi All,
Some of you have mentioned using these teensy integrated voltmeters:
So I bought a few. However, they don't come with any docs. Scrounging the Interweb has resulted in "not much".
If you know about these little beasties, my questions are:
1 - what wire does what? I'm guessing black is ground, red is logic supply and white is for the measured voltage
2 - if red is the logic supply, what's the voltage? 5V? 4.5 to 5.5? Heaven forbid 3V?!?
Thanks.
Thanks.
Smoke test time, Pal. Man up! http://www.ebay.com/itm/321224931231?var=510166520774
I'm a wuss, dude. Gotta have the docs.
But - ok. It's on you if it smokes.
Oh, that's right. To sell you another unit after you smoke one!
IMO 5V sounds like a safe bet. It says reverse polarity protection, so I'd put black to negative, and both red and white to 5V for starters. Once you verify that works, move the white wire to 7 volts and see if the display changes. If not, try the red.
Specifications:
- Measuring range: DC 0V--32V
- Input range: DC 2.7V-32V(Max Input: DC 32V. The device can be damaged if input is over 32V)
- Display: Three 0.36 "digital tube
- Measurement accuracy: 0.1%
- Refresh rate: about 300mS / times
- Input impedance: About 100K
- Dimensions:33mm*15mm*10mm
- pitch of holes:28mm
- aperture size :2.8mm
- Operation Temp: -10℃-+65℃
Wiring:- red:power supply +
- black:power supply -, measure -
- white:measure +
Package Include:- 1x Digital Voltmeter
But this is what it looks like: (seems different)Can any Forum member read this scratch?
Our two boards are similar.
Any idea what the little twisty-thingum in the corner is about?
Sounds like a plan...
Looks like maybe a variable capacitor.
Hey J,
...mmm...it's a pot. I can see three terminals and an arc of what I presume to be resist.
Maybe it's a trim to zero in the reading?
It says, "Please send your $1 to the erco twins' college fund." I've been seeing this tag in more and more items from ebay China. Hmmm, remember that trip to China erco took a while back?
The red wire is "positive power supply" according to google translate. http://translate.google.com/#zh-CN/en/電源正
ok, better translation for white (the label is hard to read) "Input positive" google translate: http://translate.google.com/#zh-CN/en/输入正
...yes! Thank you.
That actually makes sense. From the scant docs I've found, the measure range is from 0V to 100V, and that would relate to the white wire.
Funny you should ask, Dave! http://forums.parallax.com/showthread.php/150882-15-Rotary-Quadrature-Encoder-400-PPR?p=1218492&viewfull=1#post1218492
Just look at the first character of the attached chart:
Top White 0-100V
Middle Red 0-30V
Bottom black common ground
...well - look at you!
Thanks!
Black to ground.
Red to +5V.
White to a 120VAC->12VDC adapter output.
And the "teeny twistum thing" on the back of the unit is a reading zeroing trim pot - verified.
Thanks everybody.
I propose we establish a binder with our Code of Conduct and Standard Operating Procedures. We should probably get hats or badges with pictures to make it official.
May I remind you about the freebie this poor (prior to today's African inheritance, anyway) father of twins has been forced to use all along?
My free Parallax "Inventor's Wand" is also clearly visible on the desk.
Thanks. Actually, that's just one of 5 Fluke meters that I have in my vast array of tech gear...
Oh, and I didn't get these units via EDD - bought 'em off Amazon.
Well, you know - these things are great! I had previously bought parts to build essentially the same thing, but these wind up being cheaper in the long run.
Comes with CT included.
That was one scary Ebay page! :surprise:
The shipping is 10 times the selling price!
Do people still fall for that?
https://www.adafruit.com/products/705#Description
Thanks Lev.
The hack (aka "thank God for RTV!"):
Select switch center off (1k pull down mounted on the switch maintains a zero input):
One of the two variable (4.5V to 9.0V) outputs selected:
Thanks again for the tip on these nifty little tools!
