Thank you for the replies. I just thought that I remembered it and was curious. I know nothing about programming FPGAs, and what with starting to learn Propeller, I do not need anything else on my plate.
I cannot believe that it has been that long ago. I sorta dropped Basic Stamps once I got into 8085 programming, but now I have returned (like a bad dream, I guess) as I have gotten into robots.
A lower cost, and with much more logic, alternative would be the Lattice LCMXO2-7000HE-B-EVN
Yeah, there are lots of better choices now. The Mach64 requires a parallel port to program it and I don't think any modern machines come with them anymore. I bought a Mach64 kit a while back and played with it a bit but I no longer have a machine with a parallel port setup so it's just sitting in a box on my shelf now.
The Lattice Breakout EVN's all include a USB FT2232H, one channel used for JTAG ISP, and the other channel for user UART
My only peeve with MachXO2 parts, is Lattice forgot to do 44/48 pin versions!!.
They have 25 & 32 pin ones, but then jump to 100 pins if you want non-BGA.
I now have a few FPGA boards including the ones used for Propeller 2 development so I'd probably just use one of those if I wanted to play with programmable logic. I also have a tiny FPGA board called the XuLA that seems like it would be fun to play with.
FPGA's started appearing in the 2004 Catalog.
I was going to put up the catalog, but it is too large. (20 Mb).
Propeller Game Development Systems are no longer sold on the Parallax site, but are available at:
http://www.xgamestation.com/view_product.php?id=33
I did not know he had the kit:
http://www.xgamestation.com/view_product.php?id=40
Bet,
Joe
http://www.xess.com/shop/product/xula-200/
That's cute, and the SDRAM makes it useful for larger-data apps.
I see they have a new version
http://www.xess.com/shop/product/xula2-lx9/
and a larger one again, that could maybe fit a P2 (were Chip to ever do a Xilinx Build )
http://www.xess.com/shop/product/xula2-lx25/
