Hexrawler project
Hi Again,
Well, progress is slow on the old school HexCrawler. I have got the legs adjusted, so it stands. There are two servo controllers on the way to me and I just now ordered a 7.2 V, 3200mHA battery pack and charger. I will be getting a smaller rechargeable battery pack to run the BS2 board @ 9 Volts.
Now for the sensors. To start with, I will be using a Parallax four way tilt sensor and a three axis accelerometer.
With the above, I should be able to get this to do a simple 2DOF walk, with maybe a tilt control. I am aware that the BS2 will be quite taxed, and the motion will be jerky, but this is just the start of a long process.
Now my question to the forum...
What should the next sensor be? My main goal to begin with is one very decent gait without a lot of slop. Is there anything in the way of sensors that would help this goal? BTW, what is a 'gaitPIC'?
Best,
Joe
Best,
Joe
Tilt and acceleration may not be beneficial for walking. The gaits are pretty much static due to the design. I'm sure you can find some benefits if not for the learning experience.
Distance detection using a PING))) or sharp IR sensor or both is pretty cool. The beast can walk around avoiding obstacles. Also I suggest picking up a power supply. That way you're not constantly charging batteries during development. 12 servos suck a lot of power.
What type of chemistry are you using?
The small hexapod I've mentioned uses a 2-cell LiPo. It's pretty hard to beat a LiPo for power density. If you're going to making robots, it's worth getting a LiPo charge in order to take advantages of these batteries.
It looks like the gaitPIC is a slave controller that will take care of the servo control. The master control just tells it which gait to use and the gaitPIC takes care moving the servos to produce the desired gait.
Ultrasound and IR really compliment each other well.
I was very pleased how well my Scribbler 2 was able to detect objects after augmenting its IR sensors with an ultrasound sensor.
It seemed like the one sensor would work well where the other one had trouble.
Thank you again!!
Best,
Joe
