Propeller Education Kit — Parallax Forums
hacktorioushacktorious Posts: 72
edited 2013-12-27 15:42 in Propeller 1
Hello,
I got a new Propeller Education kit for Christmas. I'm having several issues and am not sure how to proceed. The first issue is I am not certain where to connect the cathode for the capacitor on the 3.3v supply. I cannot find any info in the book, just the schematic, which I thought I understood. Could someone please give the the coordinates for the capacitors?
Also, I noticed in the testing section it shows several points to test which are actually under the controller. Am I actually supposed to remove the chip to test these points? Thanks.
    edited 2013-12-26 15:23
    From the box insert, it looks like the cathode of the 3.3V capacitor is plugs into one of the rows next to the EEPROM. Since all the pins on one side of the EEPROM are connected to ground, the cathode could share a row with any of these (grounded) pins.
    I haven't used the PEK but it's common practice to build part of a circuit at a time. They may want you to test the power supplies before plugging the chip into the breadboard.
    edited 2013-12-27 05:14
    Hi hacktorius,
    the PE-Kit Fundamentals write at several places
    "Figure 3-5: Wiring Diagram – Propeller DIP Plus Kit before ICs are Connected"
    Please read the text in order to make sure you do things right.
    Can you please post what doc-files you are using?
    best regards
    Stefan
  • hacktorioushacktorious Posts: 72
    edited 2013-12-27 07:05
    StefanL38 wrote: »
    Hi hacktorius,
    best regards
    Stefan
    I am reading the "Propeller Education Kit Labs: fundamentals" by Andy Lindsay, which is what came with the kit. I'm on pages 28-31. Here is the link:
    http://parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf
    In the diagram (p.27) it shows the anode is connected to the ground (j-6, or j--7 according to the instructions) , and the cathode is connected to the LED side. In the diagram of the board it looks like the reverse. However, my confusion is that I don't quite understand the layout of the board yet. The holes are connected vertically in the diagram, would this mean the anode should be plugged into L-8? The diagram looks opposite or something.
    edited 2013-12-27 08:11
    Hi,
    I'm still not sure if I understand everything exactly. So I attach pictures.
    If you look on p.26 figure 3-3 you can see how the rows and columms are connected.
    On p.27 is the schematic where the anode of the capacitor is connected to +3.3V
    and the LEDs anode is connected to +3.3V too.
    I attached the breadboard-overview and a cut-out detail
    Now look on the detail of the bredboard and the additional text and red line.
    The anode of the capacitor must be connected to the row where the red cables are plugged in
    (one left from the ground-row)
    For building up I recommend plugging in one component and then do a short test.
    So this starts with the 9V battery-clip. Pluggin in the battery and measuring the voltage at k1 + and k2 ground
    then adding the 5V regulator tripple-checking the right wiring
    j1 must be inputpin
    j2 must be ground
    j3 must be outputpin
    connecting your voltmeter to k1 / k2 then connecting the battery and watching the voltage.
    If there is a shortcut the voltage would drop down then quickly disconnect battery.
    If everything is right check voltage on whole h3 should be 5V
    Next step plug in 3.3V regulator
    tripple-checking
    h3 is input-pin
    h4 is ground-pin
    h5 is output-pin
    again connect battery and measure voltage at k1/k2 if there is no voltage-drop
    measure voltage between ground and g5 and l5 should be 3.3V
    after that connect wire from l5 to plus-row. then measuring voltage at plus-row
    This seems to be a very slow hyper-ultra-careful proceeding. Yes it is. But how long does it take until a new part is purchised and delivered?
    And you are right in the picture on p 28 the capacitor connected to plus 3.3V is drawn opposite to the one plugged intothe plus- and ground-row
    @Parallax: hacktorious is following the instructions very carefully and found details that make no sense. Please correct it ASAP.
    hacktorious The capacitors have a plus or minus identifier on their body. Connect Anode to plus whole k5 and kathode to j6.
    Another tip. Do you have a DIP-40 socket?
    If yes plug in the Propeller-Chip in the socket. If you remove and re-plug the socket the pins of the prop-chip itself stay connected and
    keeps the pins mechanically unloaded.
    @Parallax: add a high-precision DIP-40-socket to the kit and rise the price for $1.
    As an additional protection I recommend adding 150 Ohm-resistors to ALL 32 IO-Pins.
    For 99% of all devices (switches, LEDs, I2C-devices etc) you can connect to the prop-chip this will work properly.
    But it adds overcurrent-protection to each IO-Pin.
    If you happen to shortcut an IO-Pin to ground while configured as Output-pin and set high to 3.3V the current will be
    3.3V / 150 Ohm = 22mA which can be dealt by the IO-Pin without damage. A real shortcut (0,1 Ohm) will blow up the IO-Pin.
    best regards
    Stefan
    edited 2013-12-27 08:12
    Just so were using the same meanings of "anode" and "cathode", the cathode is the side with the stripe right?
    In which case I see the anode of the first cap at L-3 and its cathode in the ground rail at position 1. I'm not sure if you've used breadboards with ground and power rails. These are vertically oriented connections instead of horizontally connected strips like those used in the main portion of the breadboard. It might be good to check some of the positions with a meter to make sure it's clear which holes are connected to each other electrically.
    I think I just found your confusion. The anode of the first cap looks like it's positioned over the ground rail but there's a black line showing it connected to L-3.
    I think the illustration would have been clearer if they had rotated the cap a bit so the anode wasn't directly over the #3 position of the ground rail. The anode kind of looks like a wire from the ground rail to L-3.
    The second cap has its anode at k-5 and cathode at j-6.
    373 x 315 - 72K
    edited 2013-12-27 08:35
    Stefan,
    I hadn't seen you're post #5 before adding post #6.
    StefanL38 wrote: »
    And you are right in the picture on p 28 the capacitor connected to plus 3.3V is drawn opposite to the one plugged into the plus- and ground-row
    I think you might be mistaking the position of the 5V cap. The anode is connected to L-3 not the power rail (if that's what you meant by the above description).
    edited 2013-12-27 10:21
    Ok, cool. Thanks for all your help. I think I got it working. I just ran the continuity tests and it seems fine.
    Thanks for the diagrams, they were very helpful.
    edited 2013-12-27 11:25
    Hi Duane,
    we were posting almost at the same time 8:11 / 8:12 so you had almost no chance to see it.
    We both needed some minutes for typing and uploading pictures. So it was a random coincidence.
    best regards
    Stefan
    edited 2013-12-27 13:16
    Interesting, in my ~30 years involved with electronics I have never heard anyone refer to the terminals of a capacitor as "anode" or "cathode".
    edited 2013-12-27 13:21
    Hi Andrew,
    I was picking up the description of the thread-starter to make it easy to understand.
    Now I'm interested: as a real experienced professional how do you call the terminals of a capacitor?
    How would you describe a hint like "connect the ...?... of the capacitor to ground" ?
    best regards
    Stefan
    edited 2013-12-27 13:24
    Do you think you don't see the anode/cathode notation since both terminals kind of behave as one or the other depending out whether or not the cap is charging or discharging?
    I haven't been involved in electronics as long but I also don't recall this terminology used with capacitors.
    edited 2013-12-27 13:47
    I thought the same. Caps have always been + or - ,unless non-polarized.
    At least that what Forest Mimms and my 40 year old books tell me.
    Is there a new definition of the capacitors leads? (Going to Wiki)
    edited 2013-12-27 14:03
    Publison wrote: »
    Been there, done that. It didn't help (much). All I could find was a reference to the anode of a battery being dependent on whether it was charging or not. I think the same applies to capacitors (though I'm not sure).
    The photo I attached earlier looks like it was taken from Wikipedia but someone added the "anode" and "cathode" captions (I found the modified image with Google).
    Don't get me wrong, there is nothing wrong with using those terms as they are scientifically correct as used, but just not common for capacitors. Terminals on polarized caps have always been referred to me as "positive" and "negative" (hence the + and - markings). Granted, an "anode" terminal is simply a positively charged element by definition, so one could say that the positive terminal of a capacitor is the "anode" when discussing the relationship between the two terminals. In my opinion, you would just confuse a lot of people by using this terminology, but they say it's hard to teach an old dog new tricks, lol.
    Duane, I don't think the fact that the positive terminal of a cap could have current flowing into it as well as out of it depending the circuit state should cause confusion since, in either case, the positive terminal is more "positive" than the negative terminal, so the anode and cathode definition would still apply whether the cap is charging or discharging. The current flow change is relative to the circuit, not the cap.
