IR Rmote Control to Boe Bot
I followed the instructions in the IR Remote for the Boe Bot and have successfully programmed a universal remote control to navigate the Boe Bot, however,
I was wondering, is it possible to program another other remote control to the Boe Bot? One that does not use the Sony TV protocol?
This is very different "encoding" than SIRC, but please note that you may get interference/overlap anytime you use two IR remotes simultaneously.
My quick perusal of BS2 examples didn't turn up an IR remote example. I'm not sure if the SIRC decoding is part of the Stamps hardware (as I believe it is with the PicAxe) of if the SIRC is decoded using PULSIN and some software.
If it's a software issue, are other protocols not worth the bother since it's not hard to find a Sony compatible remote?
@smcstudent, I don't recall if I mentioned, in the PM, the existence of software in the object exchange "OBEX" which allows the Propeller to be taught to read pretty much any IR remote. While looking the link to the software I saw several other IR related objects.
TTYTT, IR works so well that I use it a lot for simple apps. The world has gone Bluetooth, Nordic (Duane!) and Xbee crazy, but that is overkill in many cases. IR costs maybe $2 total for a sensor and dollar store universal remote. Cheap, instant magic.
