Board of Education Shield switch
I'm working on the Parallax Board of Education Shield Robotics kit. I've got the chassis set up with the servos connected, along with an indicator LED for each of the servo output pins. Even when I've got the switch on the shield set to 0, (and power is only coming from the battery pack, USB not plugged in) the LEDs still light up (depending on the sketch I've loaded). I had assumed the breadboard would only get power if the switch was on 1 or 2. Is that wrong or is there something faulty about my shield?
Thanks for any help,
Steve
Steve
Steve
