3 Ir's on Parallax Boebot?
Hi
My name is Demetri and this is an URGENT MESSAGE!!! Our competition is tomorrow, and we had to completely re-design our Boe-Bot.
We are using 3 Ir's: 1 in the front, 1 on the left side, and 1 on the right side. We are using the Board of Education, coding with PBASIC 2.5.
Basically, we need a wiring diagram such as the one pictured in "Boe-Bot Chapter 7: Navigating with Infrared Headlights" in "Robotics with the Boe-Bot".
Please, calling all Boe-Bot and/or Parallax in-general enthusiasts, I need help ASAP.
Thanks, Demetri
Thanks, Demetri
Any input?
Do you have an ohm meter? Start by confirming you have coonectivity on the third sensor like it's shown in Figure 7-7. The bread board layout should look just like the other two sensors and moved an approprate numbers of holes into the middle of the board.
