Issue with basic math calculation
                    Can anyone tell me why the following in SPIN
frequencyCalc := (4*(107.7*1000000+225000))/32768
does not yield a result of
13174
I'm kinda stuck here. I've defined the frequencyCalc variable as a Long so I know I have a 32bit space to work in. The number at its largest point is 29bits (107.7*1000000+225000)*4
I've separated each step of the calculation out to eliminate order of operators as well and I still have the issue. Is there something special I need to be doing if I'm specifying a number that is not a whole number (i.e. 107.7) for multiplication?
Thanks for any input anyone has. This one has been a toughy
13174
Here's a method to display these sorts of scaled numbers.
PUB DecPoint(value, denominator) if value < 0 Pst.Char("-") -value if value => denominator result := value / denominator Pst.Dec(result) value //= denominator else Pst.Char("0") Pst.Char(".") repeat while denominator > 1 denominator /= 10 if value => denominator result := value / denominator Pst.Dec(result) value //= denominator else Pst.Char("0")To display 107.7, you'd use.
You can actually lose precision by switching to floating point.
Thanks for the pointers about the floating point precision. I hadn't though of that, and in this case, I need to be very precise. I'm working on an FM Tuner object in SPIN for the Philips TEA5767 chip. I just now got it working and the sound quality is awesome. Best of all, I bought a lot of ten off ebay and the per chip price only cost me about 80 cents each.
I will be submitting this object to OBEX for others to use when I get done. Everyone on this forum has been so helpful.
Thanks again.
I should have also mentioned the Prop Tool can do floating point calculations with pre-compiled constants but all the numbers need to be floats. You can't mix floating point and integers.
You can use the "float" command to tell the compiler to treat a number as a floating point number such as " x = 107.7 * float(1_000_000)" but it's just as easy to add a ".0" to tell the compiler to treat the number as a floating point. The same constant could have been set with "x = 107.7 * 1_000_000.0".
The constant "x" in the above examples would be formatted as a floating point number.
I believe theres also a command to convert the pre-compiled number to an integer but I don't recall what it is.
So you can kind switch between floats and integers in precompiled code but at runtime you need a floating point object (F32 is best) to deal with floating point numbers.
I've got the code working really well now, the radio tunes nice and clear
