Issue with basic math calculation
Can anyone tell me why the following in SPIN
frequencyCalc := (4*(107.7*1000000+225000))/32768
does not yield a result of
13174
I'm kinda stuck here. I've defined the frequencyCalc variable as a Long so I know I have a 32bit space to work in. The number at its largest point is 29bits (107.7*1000000+225000)*4
I've separated each step of the calculation out to eliminate order of operators as well and I still have the issue. Is there something special I need to be doing if I'm specifying a number that is not a whole number (i.e. 107.7) for multiplication?
Thanks for any input anyone has. This one has been a toughy
13174
Here's a method to display these sorts of scaled numbers.
To display 107.7, you'd use.
You can actually lose precision by switching to floating point.
Thanks for the pointers about the floating point precision. I hadn't though of that, and in this case, I need to be very precise. I'm working on an FM Tuner object in SPIN for the Philips TEA5767 chip. I just now got it working and the sound quality is awesome. Best of all, I bought a lot of ten off ebay and the per chip price only cost me about 80 cents each.
I will be submitting this object to OBEX for others to use when I get done. Everyone on this forum has been so helpful.
Thanks again.
I should have also mentioned the Prop Tool can do floating point calculations with pre-compiled constants but all the numbers need to be floats. You can't mix floating point and integers.
You can use the "float" command to tell the compiler to treat a number as a floating point number such as " x = 107.7 * float(1_000_000)" but it's just as easy to add a ".0" to tell the compiler to treat the number as a floating point. The same constant could have been set with "x = 107.7 * 1_000_000.0".
The constant "x" in the above examples would be formatted as a floating point number.
I believe theres also a command to convert the pre-compiled number to an integer but I don't recall what it is.
So you can kind switch between floats and integers in precompiled code but at runtime you need a floating point object (F32 is best) to deal with floating point numbers.
I've got the code working really well now, the radio tunes nice and clear
