Christmas Lights
I think it was last spring or so when somebody mentioned these:
5M RGB 3528 SMD 300 LEDs Non-Waterproof Flexible LED Strip Light Lamp+ IR Remote Less than $10.
The remote is actually only the top half of the one pictured - couldn't find a picture of the one I bought.
Anyway, after blowing snow for an hour this morning when I was putting the tractor away in the shop, I saw these laying on the bench. In the spirit of the season, I brought them in and strung the around my bow window for Christmas lights. Pretty neat, I can sit in my easy chair with the remote and switch colors, patterns and speed.
These are the non-waterproof type. I bought a waterproof set last year, tested 'em but never used them. Stored them in a closed box indoors. Took them out this year and the outer vinyl waterproofing layer is all sticky, deteriorating, and getting stiff. Not sure how long they would have actually lasted outdoors.
Only one problem, I saw "RGB" and assumed the LEDs were RGB, doh! Knew that was way too good for $10.
I put a meter on the wall wart and it says 18v. Am I overdriving them and that's why they shut down after awhile? I've got another set of lights, controller, etc. I may wire them up today and see if I get the same results. How would I knock down the voltage from the wall wart? I might have to go out and look for a different one and test it before I wire it up...
I'm showing 1.3A @12v max draw, if I limit the current I can dim it all they way down to around .25a max @12v, then the blues go out then green then red so maybe that isn't it. You can run them around 9v to lower the brightness, significantly less current. Anything less than 8v seems to cause blue to drop. They also seem to work okay from a fresh 9v dry cell.
Do you have a 12v SLA battery or something to that effect to try it with?
