Profile picture in posts
Erlend
It's not important, but slightly fun: to include the Profile Picture in forum postings. Except I simply cannot find out how to do it??
Erlend
Erlend
Hello Erlend,
At the top of the Forum window is "Settings", go there.
In "Settings", on the left side of the page you'll find "Edit Profile Picture", go there.
In "Edit Profile Picture", you'll find the means to reference/upload a picture.
Good success!
I took a closer look into "Settings" and could find no way (as Erlend noted) to make a defined Profile picture to be used as the Avatar via a simple button-click or check box
The only thing I can think would be to upload the picture used in Profile to the Avatar area. As Duane noted, this means that both the Profile and Avatar images would be the same.
Erlend
BTW, I've changed your original post to indicate this thread has been "solved".
