Do you want to use the Profile Picture as an avatar? If so that's certainly possible but I think you'll have to specify the picture as your avatar (if can be the same as your profile picture).
...well, I completely misunderstood what Erlend was asking - thank you Duane for clarifying.
I took a closer look into "Settings" and could find no way (as Erlend noted) to make a defined Profile picture to be used as the Avatar via a simple button-click or check box
The only thing I can think would be to upload the picture used in Profile to the Avatar area. As Duane noted, this means that both the Profile and Avatar images would be the same.
Hello Erlend,
At the top of the Forum window is "Settings", go there.
In "Settings", on the left side of the page you'll find "Edit Profile Picture", go there.
In "Edit Profile Picture", you'll find the means to reference/upload a picture.
Good success!
Erlend
BTW, I've changed your original post to indicate this thread has been "solved".
