Rocker-Bogie versus Universal Joint suspension. — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2013-11-27 12:19 in Robotics
Pictured below is my 4x4 robot which I've shown in two videos climbing over obstacles or driving on carpet with much greater agility than my tracked or two wheel drive robots.
It's a good robot and I like the design because it always has three drive wheels in contact with the ground. But I've been reading about rocker-bogie and universal joint suspensions that allow all four drive wheels to be in contact with the ground. Here's Dino's example of rocker-bogie:
Here's the forum's Brian_B and his universal joint rover:
Does anyone have any thoughts on which design has greater merits? On the surface the universal joint design looks easier to build as the part count seems smaller. However it does have the disadvantage that the body portion is in two pieces. Rocker-bogie lets you have a single body section and perhaps works better for differential steering.
Update:
I found another kind of chassis design called a transversely split. It's basically a rocker-bogie without a central chassis.
