Here is the update from the Big Change!!! - Page 3 — Parallax Forums
1356
  • pedwardpedward Posts: 1,642
    edited 2013-11-26 08:27
    Bill, I would bet that Chip would put more effort into a self-hosting Prop dev environment than getting an ARM core up and running, that's an exercise left to others. A self-hosted environment would still work on the regular chips.
    edited 2013-11-26 08:35
    P2 chips can provide this environment IMHO. Once we have production P2 chips, they will be enough to bootstrap future propellers into running. Tons of reasons to do this. Eating the dog food to make better dog food is a significant gain, and point of sale. The gain is the control over the whole stack of technology. This is significant. The point of sale is the value added though this control, think Apple instead of Dell for example, and the fact that the technology can stand on it's own speaks to it's robustness, etc...
    Open tools can be built for whatever CPU you want. And people will too. But the core development can build up on P2 chips, and remain controlled and consistent throughout P3 development. No OS or hardware worries of any kind.
    That is if Parallax makes the P3 dev board. That one can have a P2 on it. Would be useful for other things too.
    edited 2013-11-26 13:52
    Can we talk about a new FPGA board, P3 open code, etc on another thread, and keep this for the New Update and problems?
  • BaggersBaggers Posts: 3,019
    edited 2013-11-26 14:40
    Hi Chip, I can program the DE2, and it verifies, and I can talk to the P2 with PNut, but it's not running, or I'm getting no sync, could be something to do with the expansion board?
    edited 2013-11-26 14:50
    @cluso, makes sense to me.
    @Baggers, I recall you going back to an earlier update. Does that work? I won't get to mine until tonight.
    edited 2013-11-26 15:07
    Baggers wrote: »
    When you do a Ctrl-G from PNut, does it recognize the DE2-115 w/5 cogs and 128KB hub RAM? And do you have the 2.5" x 2.75" blue HSMC adapter board from Parallax that is marked "Terasis_DE2_115"? You would connect your VGA cable to the Parallax adapter board, not the one built into the DE2-115 base board.
    edited 2013-11-26 15:16
    Chip,
    pnut.exe:
    What does Ctl-G do?
    What does Ctl-D do?
    Do you have a list of pnut commands?
    edited 2013-11-26 15:34
    Chip,
    SETX - what bits are moved?
    INCPAT/DECPAT - what do these do?
    All,
    Been working thru the instruction changes required to my P2 Debugger.
    Here are a few changes...
    movi/movd/movs -> seti/setd/sets - and there is a new setx instruction.
    I use SHR #n WZ,WC,NR in a number of places :(
    Now to look at the test style instructions :)
    I knew there would be a few gotchas with the NR but we are way better of with the new set of instructions!
    edited 2013-11-26 15:36
    Cluso99 wrote: »
    Chip,
    pnut.exe:
    What does Ctl-G do?
    What does Ctl-D do?
    If you look at the items in the menu bar across the top of the applications, they're all in there.
    edited 2013-11-26 15:39
    Cluso99 wrote: »
    Chip,
    All,
    SETX is for the five D bits between SETD and SETI.
    INCPAT goes to the next-higher bit pattern with the same number of '1' bits (%10110 becomes %11001, then %11010, then %11100). DECPAT goes to the next-lower (reverse direction).
    I'll get all the instructions documented soon.
    edited 2013-11-26 15:56
    Ctl-D (documentation toggle) but appears to do the same as Ctl-M. Perhaps its because I have an error (NR).
    I had missed Ctl-G in the Run menu. My board is not connected.
    edited 2013-11-26 17:05
    Chip,
    Now that the SETF,MOVF instructions have been removed, we no longer have incremental indexing of bytes in within a LONG.
    Have you considered a SETN instruction to modify the n-value in the following instructions.
    -MS		10010nn n0 I CCCC DDDDDDDDD SSSSSSSSS		GETNIB	D,S/#,#0..7
    --MS		10010nn n1 I CCCC DDDDDDDDD SSSSSSSSS		SETNIB	D,S/#,#0..7
    --MS		1001100 n0 I CCCC DDDDDDDDD SSSSSSSSS		GETWORD	D,S/#,#0..1
    --MS		1001100 n1 I CCCC DDDDDDDDD SSSSSSSSS		SETWORD	D,S/#,#0..1
    --MS		101000n n0 I CCCC DDDDDDDDD SSSSSSSSS		GETBYTE	D,S/#,#0..3
    --MS		101000n n1 I CCCC DDDDDDDDD SSSSSSSSS		SETBYTE	D,S/#,#0..3
    In a previous post I mentioned an issue when using INDx++ in a WAITVID instruction while multi-tasking.
    This was solved byte using a SETINDx ++1 after the WAITVID instruction.
    The new FPGA code seems to be having trouble with this arrangement and the effect is no or bad video signal.
    I am now using SETD instructions to modify the WAITVID instruction.
    edited 2013-11-26 17:18
    Here are the changes I had to do to get my P2 Debugger code to compile.
    This part was quite simple, but I had decided to use P1 instructions where possible.
    Now I need to change the instruction decode tables etc.
    Note "wait" is now a pnut reserved word and cannot be used for a pasm dat label.
    '' RR20131126   095     new instruction set/emulation/pnut
    ''                      var wait -> waitx (wait cannot be used as a label)
    ''                      parameters now start $1D0 (was $1E0)
    ''                              $1F2..$1F3 INDA, INDB
    ''                              $1F4..$1F7 PINA..PIND (read only)
    ''                              $1F8..$1FB OUTA..OUTD
    ''                              $1FC..$1FF DIRA..DIRD
    ''                      movs -> sets, movd -> setd
    ''                      shr xxx,#nn+1 wc,nr -> shr xxx,#nn wc
    ''                      setcog xxx -> setnib :setcog,xxx,#6 (2 clock delay) &
    ''                      coginit pgm,ptr -> :setcog coginit pgm,ptr,#0-0
    Thought it was worth posting this info.
    edited 2013-11-26 17:24
    I also had to change TJZ to JZ and TJNZ to JNZ
    edited 2013-11-26 17:42
    With all of these changes I'm beginning to wonder if this new processor should be called something other than "Propeller".
    edited 2013-11-26 18:06
  • jmgjmg Posts: 15,200
    David Betz wrote: »
    Do you mean other than P2 ? as in P2.5 ?
    Over at Microchip, they call anything with legs a 'PIC', which lets them boast about sales volumes etc, when really they have many different uC cores, swept under that one umbrella. ARM are a bit the same.
    edited 2013-11-26 19:41
    Chip,
    re ozprops post #73 above and a possible SETN instruction to set the "n/nn/nnn" fields...
    These are the instructions that have n, nn & nnn in their opcodes & WZ fields...
    [TABLE="width: 879"]
    [TR]
    [TD]1001100
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]GETWORD
    [/TD]
    [TD]SETWORD
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..1
    [/TD]
    [TD][/TD]
    [TD]--n
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [TR]
    [TD]110010n
    [/TD]
    [TD]nC
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]WAITPEQ
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..3
    [/TD]
    [TD]     [WC]
    [/TD]
    [TD]-nn
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]110011n
    [/TD]
    [TD]nC
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]WAITPNE
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..3
    [/TD]
    [TD]     [WC]
    [/TD]
    [TD]-nn
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]111100n
    [/TD]
    [TD]nL
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]CFGPINS
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][#]D,[#]S,#0..2
    [/TD]
    [TD][/TD]
    [TD]-nn
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]101000n
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]GETBYTE
    [/TD]
    [TD]SETBYTE
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..3
    [/TD]
    [TD][/TD]
    [TD]-nn
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [TR]
    [TD]10010nn
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]GETNIB
    [/TD]
    [TD]SETNIB
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..7
    [/TD]
    [TD][/TD]
    [TD]nnn
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [TR]
    [TD]11000nn
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]COGINIT
    [/TD]
    [TD]WAITVID
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..7 | #0..$DFF,[#]S
    [/TD]
    [TD][/TD]
    [TD]nnn
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [/TABLE]
    You will note that only the instructions GETWORD/SETWORD, WAITPEQ and WAITPNE have opcodes that have "1" bits in the 6th nibble (other than "n" bits). If these instruction opcodes were swapped with TESTB, WRBYTE/WRWORD and SQRT64/QSINCOS so that they had a "0" bits in those bits, then SETNIB D,[#]S,#6 could be used to set the "n/nn/nnn" bits (on a proviso the user had the nibble msb unused bits set as zeros).
    This way we would not require a SETN instruction.
    [TR]
    [TD]1011000
    [/TD]
    [TD]ZC
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]TESTB
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S
    [/TD]
    [TD][WZ],[WC]
    [/TD]
    [TD]---
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]1101000
    [/TD]
    [TD]fL
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]WRBYTE
    [/TD]
    [TD][/TD]
    [TD]WRWORD
    [/TD]
    [TD][/TD]
    [TD][#]D,[#]S/PTRx
    [/TD]
    [TD][/TD]
    [TD]---
    [/TD]
    [TD]f-
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]1110000
    [/TD]
    [TD]fL
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]SQRT64
    [/TD]
    [TD][/TD]
    [TD]QSINCOS
    [/TD]
    [TD][/TD]
    [TD][#]D,[#]S
    [/TD]
    [TD][/TD]
    [TD]---
    [/TD]
    [TD]f-
    [/TD]
    [/TR]
    [/TABLE]
    I realise this probably upsets some of the grouping of instructions that simplifies logic (like TESB, TESTN, TEST, CMP...)
    edited 2013-11-26 19:47
    ozpropdev wrote: »
    Chip,
    You'll see that for GETNIB/SETNIB/GETBYTE/SETBYTE, there are leading 0's on nibble #6 of the encoding. The idea is that you can do a 'SETNIB inst,value,#6' to make self-modifying code.
    For GETWORD/SETWORD, there is only one 'n' bit that needs modifying and something like 'SETBC inst,#24' can handle the modification.
    About WAITVID, note that its immediate D value can range from 0..$DFF because of special WAITVID instruction encoding.
    Do these statements address the issues you were having?
    edited 2013-11-26 19:53
    Cluso99 wrote: »
    Chip,
    [TR]
    [TD]1001100
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]GETWORD
    [/TD]
    [TD]SETWORD
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..1
    [/TD]
    [TD][/TD]
    [TD]--n
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [TR]
    [TD]110010n
    [/TD]
    [TD]nC
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]WAITPEQ
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..3
    [/TD]
    [TD]     [WC]
    [/TD]
    [TD]-nn
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]110011n
    [/TD]
    [TD]nC
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]WAITPNE
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..3
    [/TD]
    [TD]     [WC]
    [/TD]
    [TD]-nn
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]111100n
    [/TD]
    [TD]nL
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]CFGPINS
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][#]D,[#]S,#0..2
    [/TD]
    [TD][/TD]
    [TD]-nn
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]101000n
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]GETBYTE
    [/TD]
    [TD]SETBYTE
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..3
    [/TD]
    [TD][/TD]
    [TD]-nn
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [TR]
    [TD]10010nn
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]GETNIB
    [/TD]
    [TD]SETNIB
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S,#0..7
    [/TD]
    [TD][/TD]
    [TD]nnn
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [TR]
    [TD]11000nn
    [/TD]
    [TD]nf
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]COGINIT
    [/TD]
    [TD]WAITVID
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [/TD]
    [TD][/TD]
    [TD]nnn
    [/TD]
    [TD]-f
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]1011000
    [/TD]
    [TD]ZC
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]TESTB
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]D,[#]S
    [/TD]
    [TD][WZ],[WC]
    [/TD]
    [TD]---
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]1101000
    [/TD]
    [TD]fL
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]WRBYTE
    [/TD]
    [TD][/TD]
    [TD]WRWORD
    [/TD]
    [TD][/TD]
    [TD][#]D,[#]S/PTRx
    [/TD]
    [TD][/TD]
    [TD]---
    [/TD]
    [TD]f-
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD]1110000
    [/TD]
    [TD]fL
    [/TD]
    [TD]I
    [/TD]
    [TD]CCCC
    [/TD]
    [TD]DDDDDDDDD
    [/TD]
    [TD]SSSSSSSSS
    [/TD]
    [TD]SQRT64
    [/TD]
    [TD][/TD]
    [TD]QSINCOS
    [/TD]
    [TD][/TD]
    [TD][#]D,[#]S
    [/TD]
    [TD][/TD]
    [TD]---
    [/TD]
    [TD]f-
    [/TD]
    [/TR]
    [/TABLE]
    How would it not require a SETN instruction? Are you saying we could get rid of it, somehow?
    edited 2013-11-26 20:10
    Because all the instructions with the "n/nn/nnn" encoding would now become "000n/00nn/0nnn" so that SETNIB would be able to set these bits in the same manner as SETNIB can now set COGINIT etc.
    edited 2013-11-26 20:14
    Cluso99 wrote: »
    Okay, I understand. I'll look at your recommendation to see how it would fit.
    edited 2013-11-26 20:55
    Chip, regarding the INDx/WAITVID issue.
    In the previous FPGA version I used the following code
        WAITVID INDB,MYCOLOR
        SETINDB ++1
    In the new FPGA this does not work,no or bad video signal.
    If I remove the SETINDB instruction the video works again,but obviously without indexing is incorrect.
    I'm still doing some testing on this.
    I'm also chasing a issue with the replacement of POPAR,POPBR
        POPBR S1
        POPBR S2
        POPB s3
    This reads 2 longs then indexes back 1 step. This doesn't seem to work on the new FPGA.
    PNut seems to accept these KEYWORDS without error.
    I know RDAUX replaces some of these instructions, but I still haven't got a replacement to work yet.
    I keep going and see what I find.
    Great work on the update.
    Cheers
    Brian
    edited 2013-11-26 21:17
    ozpropdev wrote: »
        SETINDB ++1
        POPBR S1
        POPBR S2
        POPB s3
    Cheers
    Brian
    I'll look into the INDx issue in the morning. The encoding has changed, but if you are using PNut, it should take care of that for you.
    About POPBR: it is different than before. It used to be that the 'R' indicated reverse pointer movement (SPx++ vs --SPx). Now, all POPs are --SPx and all PUSHes are SPx++, regardless of the 'R'. The 'R' now means that instead of the address, it will use !address, or 255-address. The 'R' makes reverse addressing. If you read the AUX section of the Prop2_Docs.txt, it will explain everything about this.
    edited 2013-11-26 21:19
    Some other changes are
    For PASM code loaded with F11 use ORGH $E00 instead of ORGH $E80
    ROM Monitor entry address has changed
    ' Usage: cognew($6E4, rx_pin << 9 + tx_pin) 'start monitor in new cog
    edited 2013-11-26 21:24
    Thanks Chip
    Edit: POPxR changes from docs
    POPAR D alias for 'RDAUX D,!--SPA'
    POPBR D alias for 'RDAUX D,!--SPB'
    PUSHAR D/# alias for 'WRAUX D/#,!SPA++'
    PUSHBR D/# alias for 'WRAUX D/#,!SPB++'
    edited 2013-11-26 21:41
    ozpropdev wrote: »
    Thanks Chip
    Yikes! I didn't write those properly. The idea is there, but the syntax is not correct. They should read:
    POPAR D alias for 'RDAUXR D,--SPA'
    POPBR D alias for 'RDAUXR D,--SPB'
    PUSHAR D/# alias for 'WRAUXR D/#,SPA++'
    PUSHBR D/# alias for 'WRAUXR D/#,SPB++'
    I'll change these in the morning. Thanks for posting these.
    edited 2013-11-26 22:18
    ozpropdev wrote: »
    I found the $E00 change. Hadn't worked out the monitor address yet, so thanks.
    The new DE0-Nano FPGA code is running but my P2 Debugger is not working yet - it compiles ok. I will try just booting into the monitor straight away and see if that helps.
    edited 2013-11-26 22:53
    Just tried the balls demo on my DE0. WOW!!!
    edited 2013-11-27 01:40
    Yes, it recognises the DE2-115 w/5 cogs and 128KB hub RAM :D I also have the HSMC adapter board marked Terasic_DE2_115, and the VGA cable is plugged into that, and not the DE2 itself :D
    I'll try it again later tonight, as I'm out to do a talk about making games to a load of 6th form art students.
    @potatohead, yeah, I meant to try going back, but never got chance, will do it tonight!
