Dremel 7700
 xanadu
xanadu
                    Some things in life should not be cordless. For everything else, it needs to feel as if there is a cord, else its function becomes null.
I've always had a corded cheap knock off version of a Dremel style tool. It was worthless, no torque at all. That limited it to the kinds of jobs I don't need it for. A few months ago I was in Lowe's and saw a cordless Dremel 7700. It was around $50, I think. I opened the box on the ride home. I was excited about finally having a cordless Dremel, who wouldn’t be?
When I got home I charged the battery in the wall charger it came with. It mentioned a three hour charge time. I do not want or need quick chargers in my life. I'm a last minute guy when it comes to everything except batteries. When it comes to batteries I need maximum capacity, not three hour charge time. When I get a charger that doesn't agree with my policies… I assume the manufacturer designed it to last at least a year. It didn’t really matter because I was about to Dremel a bunch of stuff.
Back to the battery for a sec, the 7700 pack is 7.2v, and I assumed it was nickel-metal hydride. The odd shape had me guessing about the cells. Much to my dismay it turns out the thing was just as gutless as my corded one. I started questioning my own motives with Dremels, maybe I need to take up jewel crafting, and maybe I’m in the wrong hobby. I didn’t use it much after the initial disappointment, we’ll call it a learning curve and write it off. I would still periodically top off the battery. Just in case I needed to cut butter or polish some glass.
Today I needed to make the tiniest little cut in plastic. No go from the 7700. Charger had a green light but the battery was not charged. No magic cordless Dremel awesomeness anywhere in sight.
I decided to open the battery pack, and this is what I found;
Six 800mah nicads, 7.2v/800mah. Bleh…
Mechanical switch for “HI” and “LO”, more like “LOL”. The switch moves the contacts against the battery terminals. The cheese was getting deep.
No problem…
JST, now I can cord it or battery it.
7.2v? Runs a lot better on 8.2v. Mission accomplished. This thing will slice through time itself.
No problem…
It has been replaced with an 8000 10.8V lithium version that works very well, I have one at home too.
Still works fine today. I don't mind the cord.
just realized this recently
Scope I think for a kickstarter project, open-source dremel-alike with choice of motor (brushless DC motor, mains AC)
and compatible CNC mounting collar.
$25 is more like it. I looked it up and I did pay $50 at the time. It was the only cordless Dremel there. It's a shame because the tool itself is great, just the battery or possibly the charger that ruins it.
That's what I ended up doing. I found a used Dremel 4000 on craigs for $20 with all the original bits still new. Problem solved.
For drywall you ever try a sawzall?
