Protobot (My first robot) — Parallax Forums
CopperCopper Posts: 48
edited 2014-01-12 16:34 in General Discussion
I've finally started designing/building my first robot. For now, I'm using a Propeller Activity board for its brain. I like the idea of building my own “all in one” board; but the activity board seems like a good solution in the interim.
The end goal: a robot that can autonomously "wander" a table without falling off, locate a 1.5" block, pick up the block, locate a 3" red paper circle (taped to the table), and set the block on the circle. (The "game" is based on a competition a local robotics club I go to is having; my robot won't be ready in time for the competition, but that's fine).
Naturally, I'm having a little trouble staying on top of the project. I have some specific questions, but I think I'll ask them below. Like it says in the title, this is my first robot, so I'm sure there are lots of questions I haven't thought to ask, so I would really appreciate any general suggestions/advice as well. Thanks in advance.
Before this goes any further, this is very much a work in progress. For one thing, I intend to replace the majority of the metal hardware with nylon. I expect that will cut the weight between 1/4 to 1/3. It's also likely I end up with clear plex, instead of smoked (it's smoked in the model because I had some sitting around the office; and it looks better in my CAD system (Solid Edge ST6)).
Now for the good stuff: pictures. I'll point out "relevant design decisions" I made as they occur to me.
4g5zG_IwbxeifxpAWY3hLZvWR-V3lAudNlCzZohDAk2vppjE-LLzBBjOu0LEHtWByGB6L3w1UjoYVlY3x1bHBiGiKvM7OI9-Yo9gVedJvctiSz5d6FRN_eV0
The blue box is my "dummy activity board" (it'd be awesome if somebody knows of a model for the activity board. Also, if anybody wants any of my models, let me know and I'll make them available; I intend to post the whole model on grabcad or something when it's done).
Everything in the same grey as the claw was or will be 3D printed. I used a Uprint (first gen) for everything but the claw and gears which I had run on an Objet printer (polyjet 3D printer; very impressive). The resolution on the Objet is amazing. I think my claw was printed at 32 microns; but the machine can go down to 12 microns. Ultimately, I'll have all the plex pieces laser cut (does anybody have a laser cutting service for 1/4” plex they’d recommend?). I cut and drilled a piece of plexiglass I “stole” from the office for a temporary "brain shelf."
b0TeNhDMLqsUeJroWtwSSK7dS64kQBAHAFRXlUiS-COp7Be57wyNLHVhKtbf4eJRgBkSXoanzJdx-rDvy8DetsX0LrEMoubYvC3-ChoV0csP76e02PBHHseh
Parallax high speed servos and servo wheels for the drive wheels
"actuating motors": http://www.pololu.com/catalog/product/1570
battery is a cheapo I got on sale at radioshack: 8.7volts , 1800mAh if I recall.
Color pal to detect the circle.
QTI sensors for edge detection.
omni wheel : http://www.microrobo.com/48mm-lego-compatible-omni-wheel-w108.html
“Block Sensor” -> TBD
VIlKoiyHKe5yoQMdMaw0Gw8CoIsrxAm5zQJbOfAMrHsTYQcSMjlJCALX97WZHI-Jq75iI8vMjWPc55wvgw-3VHxLyLw9ToccnvEtktEQTOYlSyAI6KT007ba
I have a small pressure sensor I could put in the claw, but I'm hoping I can "see the current draw change" quickly enough to "detect claw shut" (my primary concern is that the motors current draw is not as linear as I need it to be for this application, and that the motor would damage the claw before I detected a change in current). I won’t really have any means of detecting the claw is open; but if it always starts out open with nothing in it (which it should), and closes, detects closed, and then opens a set period of time without detecting a current increase (which would indicate it had opened too far somehow). At that point, I’m in a known open state. Then, when the robot attempts to pick up the block, I’ll measure how long it takes before it detects a current increase. If it takes less time than was spent opening the claw, the claw has grasped something; otherwise, it has just closed all the way and should open back up and try again. As long as it's open enough, I don't care; and since the claw opens considerably wider than necessary, I have a good range of "acceptable openness.”
Or, I thought about putting holes in the gears in the claw, and essentially building in an encoder. I would still try to use the current draw to detect when the claw has grasped something; but again, if that’s not a safe/reliable way to detect the limits, I could use the pressure sensor. I would love some advice on reading current flow, and whether it can be a reliable method for sensing the claw has closed.
G_2rD2dZqwAvtPtzab20WDVVAhUHkEK196bgJ7UkKkDB-5Aheg_yhamTZMB4OTK-dMzgkmSVcDz3fl4pBKlV4inkzNjQvc7mvV-aGZeYxGXLmVeO4oSTOF3Y
By the way, none of the 3D printed parts are threaded in the model. FDM 3D printers generally have a slightly lower resolution on the Z axis than the X and Y (has to do with the size of the bead of plastic (sort of like the curf of a sawblade) vs. the resolution of the stepper motors). As a result, for small scale parts, it’s not uncommon (in my limited experience) for holes in the Z planes to come out a little oblong. With holes above 1/4” it’s not generally noticeable (plus, holes in the X Y planes aren’t affected). At any rate I decided to play it safe, and instead of fighting with the printer getting it to print perfect parts, I just left the holes a hair undersized and then ran them through with a bolt (I didn’t have a tap). So everything fits nice and snug. I should probably shrink the holes some more and drill them out so they’d be perfectly round too (and buy a tap).
Also, the grippers are black on the claw, because when I have the rest of the robot done, I want to try and get the claw re-printed on a Connex printer, which is basically an Objet that can combine multiple build materials into a single print job. So ultimately, what looks like they should be rubbery gripper tongs, should sort of be rubbery gripper tongs. The first claw will just be plastic.
Here's what I have so far:
Like I said before, I'm going to replace all the metal hardware with nylon hardware. Also, I haven't ordered the laser cut parts yet. I have files prepared to send off. I'm guestimating $60 - $80 dollars, which is enough money, that I figure I should finish designing everything before I order it. Mostly I need to flush out my “block sensor” and verify it will fit in the space allotted.
There's an IR receiver on top for Remote control (I wrote a little assembly driver for decoding Philips RC6 and RC6A signals (mostly as a learning exercise); I was going to share all my code when it’s finished, but if that sounds useful to anybody, I’d be happy to share it now. I’m sure it can be considerably improved, but it works).
The robot in the back is Protobot’s lego predecessor. I was using it to write some code for Protobot while I’m still building it. But one of the wheels broke and I haven't gotten around to fixing it. I have the wandering with edge detection working, nothing else (except remote control, but that’s sort of an aside to the main project).
1cjDDphP6ARV8FueRyKMowbaezYMXQy7YHD8_dzmMx8X4OIk5cTfGLUrD5a1LDrvQOvsnRtkMJ21g6D3zNQ9FXIuL2D6dDLLyfHSnM3mZ8qBuJwKxyY5WGZu
_Ryf4r32iKr8Yo74G4DAuVmTa7HylhStv3xXXu2YEc5jrp7M9rrKHC9Gdli9nKMLukm8v-x8C2QVWowUwcK7Km_vw9zMIzMr-E_ax6a-Dx2qH66YcB29hz4S
I decided to use zip ties to mount the battery just save material.
JwutI3YFCcjw-MAEk688pV0cyVzGtXtAHbrrl4WDA_pVwVlAxOGS2pzZUyiYDsrrK5hRR3qSwKQGo1q7usY5Qm_fpsPmEUTc6niVFApWm5atFYRgZy0pqLyL
I only have one size of 4/40 screws right now. When I order the nylon “hardware,” I’ll get more appropriately sized screws.
QPKdy1-_1_pI-4yTT-OOVD-R7AZ4ujF3uXo11fSAfxUBmUpTkcvuDuCOqydEqIx8EHPluU46SaaKtR57MNUUVf4tEA21LMgd9SrAcA_F3CfQcQYc-H52DmZs
Shaft collar for the D-shaft that holds the claw. With a little 4/40 brass threaded insert.
GuvqU0608mQcvuFIbw9gElWksbTB2FgKY8kme1tUFS0MfbYe_w6ty3Yd51C4ymdAl1HlKXMdT8Ze93Tv-edAkWW8LGOiOtCV5ckfliBkLfX5wkgjw9YIldOM
I can’t mount the claw until I order stuff.
_5Q_fnQSytpaKQaJR6KM-TjZvsc7P7zppziHWdGCB-QzUNtStqy1GjTTXPHVNgzH5XpPjoGR3uDYl149DyRNhkHMoyEnaUqTibU2IxOUyJ9pkbnYMG09qT7tJust a little sloppy. I could probably cut the tolerances another 0.01” or 0.005”
But hopefully it will prove out the concept.
0WEewLIJxE-0KRAbzybJsUxtJF-al4mX6-9UIQEgBhvvHmlT6m7SRS_fTVKNycKh03sqHiex8bqQD6RGk77Aa0PCyPNdMW1tVJ8IdnZ0Hvzordm7AloJRg4F
Originally, I planned on buying metal worm gears, the same size and pitch as the ones I printed (different bore; I’d have to print a little bushing so I could center them on the gearbox shafts), but after looking at what the Objet can do, I decided to print some that would just press fit onto the shaft. Unfortunately, that material (the Objet does a variety of materials) might not work for a worm gear. Too “sticky.” It might work with some lube. I haven’t really decided what my next move is. I could look into different materials on the Objet, and try to find a lower coefficient of friction. I would like to stick with plastic. It feels right. I figure the only reason not to use a metal worm gear, is it assures the claw teeth will fail first; but I suspect given the geometry involved with a worm gear, regardless of material, it’s pinion always fails first (spur gear, not sure I’m using “pinion” correctly). Which in this case is unfortunate. Printing another worm gear after 5-10 hours of run time (which would be like 50-100 hours of robot time, given the claw won't be continuously running) is no big deal. If the teeth on the claw fail, I have to print an entire replacement claw.
0pOzbr-Y5W7z7XdzyFbUfkqk8OrD5H17pa1iDY1o65ILSnxSpiM_SQtYNeDVr4moTDer9IfV9oGpIuqywDp2jog6D3LN-YOiPvhv8kpN7Vyp2jKVyapY9HqEtg
Like I mentioned earlier, I need to finish designing my block sensor before I can/will order my laser cut parts. Above, I have a Ping sensor standing in for my block sensor; but I don’t think I want to use a Ping sensor for this. I really only want to “sense” a small area (1’-2’) in front of the robot; that way I don’t have to worry about the robot detecting the walls in the room or a chair 2’ from the table or whatever. I saw a video of a boe bot “object following” with IR sensors (http://www.youtube.com/watch?v=T0WVKffg-ns). I would like to use IR for my block sensor; but I’m not sure how to best approach it. To experiment, I set up two IR leds on either side of a single demodulating receiver (38khz; I got the receivers with a PE Labs kit) and it sort of works. However, it seems to lose track of stationary objects. When the receiver is moving, or the object is moving, the prop chip sees it; but if you set the block in front of the receiver, after a second, the prop chip loses sight of it[the block]. If you look at the receiver signal line with an oscilloscope, when everything is stationary, there are recurrent “periods of detection.” So one idea I had for improving performance, was to sample the receiver for 1ms periods or so, so I can catch at least one “period of detection.” But I’m wondering if I need two receivers. It looks like most of the BOE bots doing IR object avoidance use two receivers; and I’m not sure why. Also, for aligning the robot with the block, the PE labs talk about sweeping the IR Led from a 100% duty signal to a 0% duty signal to get a distance reading. Couldn’t I use a single receiver, and sweep the IRs, then when both IRs are detected at the same duty cycle (whether it’s 80%, 50%, or 100%) then I’ve “triangulated” the block? Keep in mind there will be nothing else on the table to interfere with the sensor, so it can afford to be a little rudimentary.
This post is stupidly long.
In short:
Does anybody have a laser cutting service for 1/4” plex they’d recommend?
(I found these guys, and went through their tutorial http://www.customlasercutting.com/info/tutorials; but they don’t carry smoked plex in 1/4” ; I didn’t do any price comparrisons either.)
Does anybody know where I could get a model for the activity board (to lazy to model it for this project)?
Does anybody have experience making / 3D printing worm gears?
I have virtually no experience with IR object detection. Is this a reasonable approach to detecting a 1.5” block (there will be no obstacles)? How should I approach aligning the robot with the block?
Again, thanks in advance for any suggestions/advice; and I’d be happy to answer any questions.
First steps.
<span style="background-color: transparent; vertical-align: baseline;">
    edited 2013-11-01 12:54
    Very nice robot!
    I really like the 3D printed parts.
    Chris Wardell
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-11-01 13:20
    Nice job thus far. I am not sure if Rich offers this as a service or not but I am pretty sure he will chime in soon and give you some laser cutting leads.
    edited 2013-11-01 13:24
    Amazing. I'm stunned this is your first robot. Makes me wonder what your 20th bot is gonna look like.
    edited 2013-11-01 13:52
    Agreed, you're off to a great start, especially since this is your first robot. Well done!
    My only comment is in regards to dead reckoning, or navigation by odometry and counting wheel revolutions, if that interests you at all. You want to avoid skidding your wheels to retain accuracy. Your bot is fast and long. Long, in that your battery CG appears to be a ways behind your front drive wheel axle centerline, so there is more weight on your tail omniwheel than a robot with center-mounted wheels, like a Scribbler, S2 or Eddie. That pendulum effect works against a differentially-steered robot on fast turns and bumps (more weight on your omniwheel means a bump on your omniwheel may steer your bot in an unintended direction). To "mitigate risk" you can slow down and/or shift some weight off your omniwheel and forward toward your drive wheels.
    Other than that, it looks fantastic and I also look forward to seeing where this and your future bots take you!
    edited 2013-11-01 15:17
    I agree with the other, this is looking great.
    This video explains a lot about the CG position stuff erco mentioned. I thought it well worth the watch.
    What about Lego worm gears? They're probably not the right pitch but it might be worth using the same pitch as Lego gears in your robot in order to take advantage of some of the Lego parts. I use Lego gears and turntables in lots of my robots.
    If you don't already know about it (and even if you do), Bricklink is a great place to buy Lego gears and parts. Here's link to some of their worm gears.
    edited 2013-11-01 19:41
    Holy smokes! That's quite the tour de force, especially for a first robot!
  • CopperCopper Posts: 48
    edited 2013-11-02 16:13
    Thanks for all the positive feedback. I really appreciate it.
    I watched David Anderson’s robot presentation (Very informative. Thanks Duane. PS: I’m also a big fan of legos, but was afraid of trying to manufacturer teeth that small).
    I had thought some about dead reckoning. I started this project before parallax released their ActivityBot Encoder Kit http://parallax.com/product/32501; but I could simply buy that kit (and wheels I expect), and attatch the encoders to the underside of my servos. Given their profile (mainly being so close to the wheels) I don’t see a huge downside. That’s probably what I’ll do when I decide to start experimenting with that stuff. Or I could redesign my servo mounts to make room for the encoders on top.
    Also, has anybody tried to use a spare cog to monitor servo pwm channels, and try to estimate position from that? I don’t know that even purpose built continuous rotation servos will reliably rotate the same number of degrees given a particular pulse width, but in a perfect world they would, right? If that’s the case, then you could just experimentally determine how many degrees of rotation you get for each different pulsewidth you will ever send the servo (unless it appeared to be a fairly linear relationship, then you could use a formula; also, you would have to determine your degrees for each pulsewidth at the last second so you account for that particular robot’s weight with that particular battery running on that particular surface, etc.), and then how far you have gone based on total degrees rotation (positive or negative) and the diameter of the wheels.
    It would probably only work on smooth level terrain. It it’s possible at all. Just a thought I had...
    At any rate, there was also a section in that video where he discussed IR object avoidance. Curiously, he had yet another configuration of LEDs and Receivers. He had two central LEDs with two receivers, a couple inches away, on the outside. From what I’ve seen, It looks like most of the boe bots have two separate “emitter + receiver” pairs facing forward but away from each other. I did some more reading this morning, and finally came up with the right google search: “IR object following” (I had been searching for “IR object detection,” which was less relevant to this application) and finally found some good stuff.
    In case anybody else might be interested:
    http://www.mycontraption.com/desktop-robot-object-tracking-with-infrared/
    http://letsmakerobots.com/node/4428
    both of those links describe using basic IR detectors (as opposed to demodulating IR receivers) for basic IR object following.
    Neat looking product, and a video demo
    http://www.robotshop.com/en/dagu-compound-infrared-sensor.html
    http://www.youtube.com/watch?v=PYDctJ_Ouw0
    also uses basic IR detectors, meaning I would have to accommodate for the ambient IR light, in addition to needing the appropriate circuitry for reading analog inputs with the propeller (I would use RC circuits; is there a better/different way for the prop chip to read analog inputs?)
    Back to emitter/receiver configurations, I think I would like to use a single receiver, with two emitters set to either side. I suppose using two receivers might maximize my “sensor range,” but it seems like I should be able to do it very nearly if not just as well with one receiver. Unfortunately, I haven’t had much time to experiment with it yet. Any thoughts?
    (I refuse to cut leads until the last second; you only get to cut them once)
    For whatever configuration I go with, I’m going to want to move things over to a little custom built “perf board sensor module” with female headers so I can just jump it to the Activity Board’s bread board. I have done some soldering (and desoldering), but I’ve never worked with perf board before. Does anybody have any tips or links I should read?
    As for the claw, I think I’ll just go with what I have, and find some appropriate lubricant if I have too; and plan on reprinting the worm gear (and maybe the claw) in a less “sticky” material.
    Also, I discovered today the robotics club I go to has access to a laser; so next Monday, I’m going to go look at getting some parts cut.
    rg6e8DgxtmNq8G_lF7NQ4Xi-nFftffAQkdejX-an2tIg0nFp-XDhL6DcXIirCcuaXcJv6iBzBDLwsqU3KV1LUJAYRVurJloYTtoJJ4oKgGE3T2IqIobe3ANZ
    Another horrendously long post.
    Again, thanks for the feedback.
    1024 x 768 - 49K
    1024 x 768 - 104K
    edited 2013-11-03 01:09
    Copper wrote: »
    I've purchased the new ActivityBot wheels and the high speed servos but I couldn't bring myself to pay $38 for the encoders. I'm pretty sure I can make my own encoders for a couple of dollars.
    I've tried to add encoders to the inside of servos a couple of times. One attempt used magnetic encoders and another attempt was using a P5587 encoder erco gave me. It may be possible to get either of these methods to work well but just adding encoders wheels is a lot easier.
    Copper wrote: »
    Something like this may be possible if you were willing to spend the required time to come up with a good calibration table but again, adding encoder to the wheels would be so much easier.
    I learned the CR servo that came with the BOE-Bot are pretty consistent with their speed for any given servo pulse. Once again following erco's lead I attempted to record the path my robot took. I drove my robot by remote around a (very lumpy) figure 8 path while the robot recorded the pulses to the servos on a SD card. I was surprised at how well the recorded path matched the original path.
    If you're not using encoders to monitor speed, then you want to make sure your servos have a well regulated power supply. If you power your servos directly from the batteries, the speed of the servos will change as the voltage of the battery pack drops.
    Phil wrote a good article about using encodes for odometry. I thought I had a link to it in my index but I was wrong. Hopefully someone will provide a link to it.
    Copper wrote: »
    The Scribbler 2 uses two IR emitter and a single receiver.
    The Let's Make Robots link above is to a post by "OddBot". OddBot works for Dagu and I'm pretty sure he's the one who designed the compound IR sensor you also linked to.
    IMO, neither IR sensor or ultrasound sensors are reliable enough to use alone. I was very pleased to see how well the two sensors complimented each other when I added a ultrasound sensor to my S2. Objects not seen by one sensor were usually seen by the other. The only exception was our couch. The IR sensors were too low to see it and the ultrasound was absorbed by the couch. The robot didn't detect the couch until the ultrasound sensor was pushed up against the couch. When the padding of the couch was compressed, the ultrasound appeared to be able to see the inside frame of the couch.
    Copper wrote: »
    I use perf board a lot in my projects. While I still occasionally use the cheap stuff with a little circle of copper around the holes on one side of the board, I usually use the more expensive perf board with through hole plating. Parallax sells some nice perf board which has a ground plane in between the holes and pads. The Parallax perf board has a couple vdd and vss buses. While these buses can be useful, I think they are more frequently in the way. SparkFun's perf board doesn't have these buses so I probably use SparkFun perf board more than I use the perf board from Parallax.
    One reason I don't like the cheap perf board is the little copper rings can easily come off when a part is being soldered.
    I don't know if you've ever used DipTrace or other PCB layout software but once you get used to laying out boards with the software, it becomes faster to design the board with the software and then have the boards made by OSH Park. The main problem with having a custom PCB made is waiting the three weeks for the boards to come in. Since I often have multiple projects going at once, I'll work on one of my other projects while I wait for the PCBs to be made.
    Using a custom PCB is faster than having to make lots of point to point solder connections when using perf board.
    Copper wrote: »
    Wow, that's amazing precognition you have there. How did you know this was going to be horrendously long?
    It's always fun to see other people's robot projects. Thanks for sharing your progress with us.
    edited 2013-11-03 15:22
    Wow, Duane, thanks for the post. I really appreciate your taking the time. I am definitely going to put some forethought into dead reckoning on my next robot. I’ll probably experiment some with trying to build encoders similar to Parallax’s; it looks like, it might be worth working with my current wheels some. I had forgotten, but they look like they were almost made for it (despite parallax noting the servo wheels don’t work with the BOE-Bot Encoder Kit)
    Maybe I could color half the ridges with white-out or something, but it seems worth considering (and of course I could just order the activity bot wheels). Or I could use DC motors. Then I would have lots of encoder options to explore.
    Also, all this dead reckoning talk reminded me I currently don’t have any way to detect the claw’s “wrist angle.”
    So much to keep track of.
    I thought about building an encoder for the D-shaft (I think of it as the wrist), but given it shouldn’t be rotating much more than 90 degrees, I think I’m leaning towards just using a nice potentiometer. I have a pretty nice one I “rescued” from an old sony 5 disc changer; I might just mount it underneath the “wrist shaft” and model up some little gears for it.
    That’s sort what I figured. Good to know though.
    Also good to know. I’m actually pretty impressed.
    That would explain why they’re so similar. Definitely an approach to keep in mind.
    You’re in good company. Parallax has a nice PING/IR kit http://parallax.com/product/725-28998, but I already have a coulple ping sensors, so I would probably just 3D print a mount that would incorparate an IR emitter and reciever.
    However, for this project, given the only thing I’m going to try and “detect” is a wooden block, I think I might try and get away with IR alone. I could always add a ping sensor later.
    Hearing the S2 uses a single receiver and two emitters was enough to get me back on that project. I moved my sensor over to my development board and started writing a little PASM driver for monitoring the block sensor. I have a spin method that works okay, and could maybe be improved; but I want the speed for when I incorporate a “duty signal sweep” on the LEDs. I also just like the practice.
    EPRa-br6HrF5IEE7sf0H3p7Tzsv3Fx0nQIQePSOogdK9YXqIDfrnPHmiBse5zM1fplAPSDmR5eMld2K_Y_1KAT_j3vkWWu8tlV3EpEFc_aK0JEpJtKzv9c0p
    It sort of works. Unfortunately, I’ve got my left and right readings tangled up somehow. Even when you remove one of the leds, if one detection is made, both are reported as having detected an object.
    I think the problem is in there somewhere; I’ll attach the whole code too (just didn’t want to make a mess).
    sample                  mov     :Ldetect, #1                                    'reset "detection registers"
                            mov     :Rdetect, #1
                            mov     ctra, L_cntr                                    'L_IR -> ON
                            mov     :time, cnt                                      'set up loop
    :rollover_1             add     :time, _space           wc
                  if_c      jmp     #:rollover_1
    :check_left             and     S_PINmask, ina          wz, nr                  'start loop
                  if_z      mov     :Ldetect, #0                                    'if detected, set to 0
                            cmp     :time, cnt              wc
                  if_nc     jmp     #:check_left                                    'loop
                            mov     ctra, R_cntr                                    'L_IR -> OFF ; R_IR -> ON
    :rollover_2             add     :time, _space           wc
                  if_c      jmp     #:rollover_2
    :check_right            and     S_PINmask, ina          wz, nr                  'start loop
                  if_z      mov     :Rdetect, #2
                            cmp     :time, cnt              wc
                  if_nc     jmp     #:check_right
                            wrlong  :Ldetect, left_addr
                            wrlong  :Rdetect, right_addr
                            jmp     #cmd_done
    :time                   long 0
    :Ldetect                long 0
    :Rdetect                long 0
    I will absolutely be looking into getting some custom PCB boards made. I need to choose and start learning a PCB layout “solution.” I have access to some software that integrates with my CAD system. I should probably check that out first.
    Again, thanks for the great response.
    I’ll definitely try to keep this thread updated. Tomorrow I’m going to order the nylon hardware for the final assembly, and then I’ll be working on incorporating a potentiometer into the "wrist."
    edited 2013-11-05 08:51
    So I managed to get my basic object detection subroutine working. The IR receiver I'm using (http://www.parallax.com/sites/default/files/downloads/350-00014-PNA4601M-Infrared-Reciever-Datasheet.pdf) seems to have a "cool down" period. Or a delay. I'm not exactly sure. Any how, putting a little break between switching LEDs fixed things. Later I'll experiment with shorter "rest periods." Tomorrow, I'll start adding the duty signal component for "IR distance detection" (I'm not going to bother with units I don't think; so I've been thinking of it as "IR intensity detection").
    edited 2013-11-05 18:47
    I finally ordered my nylon hardware. When I went to do it yesterday, I realized all the nylon nuts are a little bit thicker than the metal ones; so I had to adjust the model. It didn't affect things very much; but it did move the slots on the laser cut front bumper "out" 0.0164" Virtual prototyping is a life saver. I cannot imagine designing anything without CAD.
    I decided to go back to smoked plex. The laser cutting service I was looking at didn't offer smoked plex in 1/4", so I was considering "clear," but I think I like smoked better.
    My block sensor will (hopefully) mount on the four screws on the top side of the bumper.
    As for the "wrist sensor" (for detecting wrist angle), I came across this:
    http://www.robotshop.com/en/softpot-rotary-potentiometer.html
    I'm going to have to look at it more carefully tomorrow, but I'm thinking I can print a modified version of the shaft collar I printed for the D shaft (one with a little bump to line up with the soft pot's contact surface) and sandwich the soft pot between it and the plex on the "left" side of the robot (the left side of the robot being on the right side of the picture above; the side without the spur gear).
    780 x 531 - 153K
    818 x 557 - 94K
    904 x 536 - 197K
  • Kerry SKerry S Posts: 163
    edited 2013-11-06 05:00
    For laser cut plastic try http://www.zlazr.com/
    I needed some special size 1.1" x 1/16 round lenses made for a new product sample run ASAP. They had some similar, but too small, on E-Bay so I messaged them on Friday evening what I needed. They posted a custom listing for me Saturday night (after he understood just what I wanted) and then cut them on Sunday and mailed them out for me on Monday. I was amazed.
    Great job on the robot design! It will make an excellent topic of robot design engineering for my son.
    edited 2013-11-06 08:23
    Copper wrote: »
    I have one of those softpots but I haven't used it enough to have much of an opinion about how well they work but they do seem like kind of an awkward way to add position feedback. As I mentioned earlier, I've been experimenting with magnetic encoders for position feedback. What's nice about the magnetic encoders is they don't wear out the way potentiometers do. Phil used some refrigerator magnet tape and a hall-effect sensor as a position feedback device. Phil's method is nice since you don't need access to the center pivot point.
    edited 2013-11-06 12:31
    That soft pot won't work anyhow. Too big. My thinking for using a pot instead of an encoder was that an encoder doesn't necessarily indicate a known position. A typical encoder knows how fast and what direction a shaft is rotating, but not what direction it's "facing." I read through Phil's refrigerator magnet tape and a hall-effect sensor where Beau Schwabe (Parallax) pointed out you could use the "gap" as a means of determining what direction the shaft is "facing." I have some little IR "trip sensors" from a printer I took apart. I could use one of those and make an encoder wheel with a "chipped tooth." It would be cheap. Plus, like Duane Degn said, it shouldn't wear out. I would just have to add in a little routine when the robot starts up to "position the wrist" the same way I have to "position the claw pincers." I still think there's an argument for using a pot instead; since the wrist doesn't rotate more than 90 degrees (a pot would work for more than 90 degrees, but that's all I need), a pot could give me a simple value indicating the current position. No smarts.
    hmm...
    edited 2013-11-06 12:48
    Copper wrote: »
    The magnetic encoder I linked a couple of times gives a 12-bit position as feedback. Post #15 of the software thread shows the numeric feedback from the encoder.
    Copper wrote: »
    I read through Phil'srefrigerator magnet tape and a hall-effect sensor where Beau Schwabe (Parallax) pointed out you could use the "gap" as a means of determining what direction the shaft is "facing."
    I'd be very hesitant to rely on a gap. What's the difference between a gap and very slow movement? IMO, some sort of limit switch would be a better alternative.
  • W9GFOW9GFO Posts: 4,010
    edited 2013-11-06 12:50
    NWCCTV wrote: »
    Somehow I missed this thread. Very nice robot! What CAD software do you use?
    I am happy to do laser cutting for robotics projects. Keep me in mind if you need to do hundreds or thousands, or for those that do not have access to a laser and need small quantities I can help there too.
    edited 2013-11-06 18:18
    First:
    quote_icon.png Originally Posted by W9GFO
    Solid Edge ST6. I work at a little Siemens software reseller. So I have a free license.
    Also, hopefully I'm going to get my parts cut on monday at one of the local colleges. I'm only building one Protobot, and all my parts fit in a 6.5"x10" rectangle (if you open the drawing pic in a separate tab, the original image is to scale). But thanks for the offer. I'll keep it in mind.
    Second:
    Encoders. I need to spend a little more time reading about encoders. At some point I read a little about incremental encoders; but today is the first I've ever heard of absolute position encoders. I think the magnetic encoder Duane Degn linked earlier (I have to read more about that too) would be considered some sort of absolute position encoder. For anyone who might not know, there are "magnetic encoders" that measure the angle a magnetic field intersects a "sensor" to determine the encoder's absolute position. Go figure. BTW: for anybody who might be wondering how non magnetic absolute position encoders might work (like I was all morning) they utilize an "encoded element" (like a wheel or a strip; similar to incremental encoders) with each identifiable position uniquely "labeled"
    like that.
    So, the question is, how best to translate the rotation of the wrist to exactly what kind of absolute position encoder?
    PS: If I didn't want to use an encoder, I could probably build a potentiometer into my wrist joint pretty easily. I would just need to mount some sort of C shaped ring around the d-shaft on the exposed side of the plex, and then mount a wiper off the d-shaft. But I should become familiar with encoders regardless.
    edited 2013-11-07 11:00
    I came across a neat approach to making your own absolute position encoders.
    http://botscene.net/2012/10/18/make-a-low-cost-absolute-encoder/
    The idea is to use an IR emitter and detector to determine the position of the gray scale wheel. (the approach above actually takes two detectors; but given I don't need more than 90 degrees of rotation, I'm thinking about trying it with one sensor, and a simpler wheel
    "that" wrapped around a 150 degree arc or something)
    Besides being dirt cheap to build (I already have everything I need) it only takes two lines on the propeller. 1 for the LED and 1 for the detector. So long as I accommodate for ambient IR, it seems like it should be good enough for my robot (if I wanted to try and eliminate ambient IR (enclose the sensor some how) then it would only take one line on the propeller; since I could just run the emitter off the rail).
    Duane Degn wrote: »
    I'll probably end up using limit switches in place of, or at least in addition to whatever simple position sensor I go with. I probably need to put a bump sensor on the front of the robot too, to detect the block. I just like to do things the hard way.
    1024 x 768 - 17K
    edited 2013-11-12 08:53
    Quick Update:
    I got my laser cut bumper assembly laser cut.
    1024 x 768 - 104K
    1024 x 768 - 84K
    1024 x 768 - 77K
    1024 x 1365 - 183K
    1024 x 1365 - 111K
    1024 x 1365 - 104K
    edited 2013-11-12 18:44
    I'm having some trouble with my block sensor.
    The idea is to use two IR LEDs set on either side of a receiver, and sweep the intensity of the light emitted by each LED to determine which LED is closer to the target.
    I have both LEDs running into P6; the duty signal pin. I can get the LEDs to light with little blinky spin programs, so I know the pins and LEDs are good. I also have a little spin program for IR distance detection I took out of the PEkitlabs and it works.
    If I run my code with the LEDs running into ground, I get lights, so I think the object detection routine is being called and executed. But If I run the LEDs into P6, I do not get lights. Which would lead me to beleive I have improperly configured ctrb for generating duty signals, or P6 is not an input somehow, or for some reason I'm unaware of, I can't run both LEDs into P6 (they alternate so only one is on at a time (I did wonder if I need some diodes protecting the LEDs from each other, but they seem to still work just as well as when I started)) or something else I either don't know or haven't thought of.
    I tried breaking out only the necessary code for running the LEDs and duty signal, so it would be easier to trouble shoot.
    CON
      _clkmode = xtal1 + pll16x                  ' System clock &#8594; 80 MHz
      _xinfreq = 5_000_000
    PUB main
      cognew(@align, 0)
    DAT
                            org     0
    align                    mov     temp, #1                                        'config pins
                            shl     temp, #9                                        ' ...
                            muxnz   dira, temp
                            mov     temp, #1
                            shl     temp, #7
                            muxnz   dira, temp
                            mov     temp, #1
                            shl     temp, #6
                            muxnz   dira, temp
                            mov     temp, #1
                            shl     temp, #2
                            muxnz   dira, temp
                            muxnz   outa, temp
                            mov     S_PINmask, #1
                            shl     S_PINmask, #8
                            muxz    dira, S_PINmask                                 'verify sensor set to input (presumes Z==0)
    :start                   mov     ctrb, G_cntr                                    'set ctrb for duty signal
                            mov     :duty, top
                            mov     :minLduty, top
                            mov     :minRduty, top
    :loop                   sub     :duty, :dinc                                    'dinc :duty
                            mov     frqb, :duty                                     'config ctrb for new duty
                            call    #sampleCALL                                     'scan for block
                            cmp     left, #0                wz                      'check left
                  if_z      mov     :minLduty, :duty                                'if detected, store current :duty
                            cmp     right, #0               wz                      'check right
                  if_z      mov     :minRduty, :duty                                'if detected, store current :duty
                            cmp     :dinc, :duty            wc                      'check :duty
                  if_nc     jmp     #:loop                                          'if :dinc < :duty, loop
                            andn    outa, temp       'turn debug light off
                            jmp     #:start
    :duty                   long 0
    :minLduty            long 0
    :minRduty           long 0
    :dinc                   long 1000
    DAT
    sampleCALL
    sample             mov     Ldetect, #1                                     'reset "detection registers"
                            mov     Rdetect, #1
                            'L_IR
                            mov     time, cnt                                       'set up loop
    :rollover_1            add     time, _space            wc
                  if_z      mov     Ldetect, #0                                     'if detected, set to 0
                            cmp     time, cnt               wc
                            'rest
                            mov     ctra, #0                                        'L_IR -> OFF
                            mov     time, cnt                                       'rest
                            add     time, _space
                            waitcnt time, #0
                            'R_IR
                            mov     ctra, R_cntr                                    'R_IR -> ON
    :rollover_2            add     time, _space            wc
                  if_z      mov     Rdetect, #0
                            cmp     time, cnt               wc
                            mov     ctra, #0                                        'R_IR -> OFF
                            'report
                            wrlong  Ldetect, left_addr
                            wrlong  Rdetect, right_addr
                 '           rdlong  temp, PAR
                 '           cmp     temp, one               wz                      'check sample or sampleCALL
                 ' if_z      jmp     #cmd_done
    sampleCALL_ret          ret
    DAT
    'SPIN <-> PASM addr's
    cmd                     long 0
    left                    long 0
    right                   long 0
    sensor                  long 0
    gnd                     long 0
    'PASM -> SPIN cmd_status values
    zero                    long 0
    one                     long 1
    'BS values
    FReQA                   long 2040109                                            '2040109.4656 == (frequency*2^32)/clkfreq
    top                     long 4294967000    '(round to nearest :dinc) (could +:dinc for max range) ' 2³²== 4294967296
    _space                  long 160000                                             '2ms
    L_cntr                  long ((100 << 26)|9)
    R_cntr                  long ((100 << 26)|7)
    G_cntr                  long ((110 << 26)|6)
    S_PINmask               long 0
    Ldetect                 long 0
    Rdetect                 long 0
    time                    long 0
    temp                    long 0
    cog                     byte 0
    mem_addr                res 1
    left_addr               res 1
    right_addr              res 1
    sensor_addr             res 1
    gnd_addr                res 1
    L_IR                    res 1
    R_IR                    res 1
    S_PIN                   res 1
    G_PIN                   res 1
    edited 2013-11-15 12:17
    I got the QTI sensors, and the color PAL hooked up (hopefully I have enough IO on the activity board to get everything connected at the same time; at the moment, I don't even know what everything is...).
    Anyhow, with all the QTI sensors hooked up, I could start working on a simple random walk routine. It's fairly random. It just uses the ? random operator. So technically It's only sudo random. Plus I limit the spin duration (.25sec min, 3sec max (direction is random)), and it has a simple escape routine it goes into when it gets stuck.
    The idea is to have the robot just randomly run around the table until it detects an object, then exit the random walk while it aligns with and picks up the block, then re-enter the random walk; but this time instead or searching for an object, it will sample the surface color until it finds the circle where it's supposed to set the block.
    Unfortunately, I have not made any progress with the block sensor. I may have some time to work on that today.
    I also haven't even started working on the wrist position sensor, or the grip sensor.
    Things are moving along, but I've got a ways to go.
    edited 2013-11-15 12:30
    Copper wrote: »
    Welcome to the real world of robotics! :)
    edited 2013-11-15 15:15
    Copper wrote: »
    . . . It's fairly random. It just uses the ? random operator. So technically It's only sudo random.
    The state of the system clock "cnt" is pretty random if the chip has even been powered up before. The clock doesn't reset when the Propeller is turned off. You can use it as a "seed" for the pseudo random number generator to get something which is pretty darn close to random.
    There's also a real random generator with uses some internal noise to generate real random numbers.
    It's good to see your robot moving. How about a figure 8? (I figure it's my turn to ask since erco just asked another roboticist about entering the challenge.)
    edited 2013-11-15 18:41
    Duane Degn wrote: »
    That's awesome. I will definitely do that. It's a particularly good Idea in this case, since the random walk doesn't start until I hit a button on my TV remote.
    As for the block sensor, I'm totally stuck. I've checked everything I can think to check, and everything looks correct; but no lights. If I comment out the line that sets ctrb to duty mode (00011000000000000000000000000110 specifically) I get lights; but of course, no duty signal.
    To check the circuit, I modified the PElabs example spin program, and it effectively does what I want, just really slowly (and it's not as granular as the PASM code should/will be).
    pekittest.spin
    (assumes the object is centered between LEDs)
    The only difference between it and my PASM code (besides the way the frqa value is managed) is that the spin code used ctra for the duty signal, and ctrb for the 38khz signal, where the PASM code uses ctra for the 38khz signal, and ctrb for the duty signal.
    align                   mov     ctrb, G_cntr                                    'set ctrb for duty signal
    mov     frqb, #0
                            mov     phsb, #0
                            mov     temp, #1
                            shl     temp, G_PIN
                            muxnz   dira, temp
                            mov     :duty, top
                            mov     :minLduty, top
                            mov     :minRduty, top
                            'report
                            wrlong  :minLduty, left_addr
                            wrlong  :minRduty, right_addr
                            jmp     #cmd_done
    :duty                   long 0
    :minLduty               long 0
    :minRduty               long 0
    :dinc                   long 1000
    02_BlockSensor_PASM.spin
    (I'm pretty sure I've verified everything outside of "align" is working; there are no hangups or anything, just no lights)
    I'll probably spend some time with my oscilloscope tomorrow.
    edited 2013-11-15 19:35
    I'm not familiar with setting the direction of a pin mask with this code:
    muxnz   dira, temp
    I don't see any code to set the z flag.
    Wouldn't be easier to just use the following?
    or      dira, temp
    In the Spin example, there were two pins set as outputs. Are you sure you're setting the needed pins to output?
    edited 2013-11-16 12:20
    Duane Degn wrote: »
    or    dira, temp
    Well, first, I assumed (correctly I think) the Z flag initializes to 0, and operated off that assumption. I'm fairly confident the pins are properly configured given the lights come on if I comment out the instruction that sets the duty counter. I've also used this method successfully before.
    That being said, I decided to switch all my mux's to or's and andn's anyways. Having the flag in there is an unnecessary complication. Not only is this my first robot. This is my first micro-controller. I have some programmer friends who help me out from time to time; but for the most part I've just been making it up as I go along.
    In addition to getting rid of my mux commands, I also switched the counter modules around to match the spin code (to no avail; I'm pretty sure both counters are identical, and it shouldn't matter which is the duty mode counter), and then I took a look at things on my oscilloscope.
    (I also tried adding the 128th second delay after setting the duty signal that's in the spin code I somehow missed earlier, and presuming I did it right, no desirable change (it is slower now))
    I was surprised. According to my oscilloscope, with the duty mode counter activated in either the non-functional pasm code, or the spin code, the peak voltage was ~4.3v (probe on the left LED(P9) anode). In the spin code, the voltage sort of swept down to ~3v, then just dropped to zero (the lights appear to dim correctly, but I could never get the distance output to be less than ~170/256). I could probably smooth out the sweep with capacitors. But I am very confused to see more than 3.3v coming out of the propeller. My understanding was that by using the counter to control what percentage of the time P6 is an output (all in one cog; I realize different cogs can have the same pin configured as an input and an output), I was effectively controlling what percentage of the time P9 and P7 had a ground to go to (and that outa[6]==0 so no output (I could add a diode to P6 just to make sure it's never an output)). I'm flummoxed. Why doesn't it sweep all the way down? Even if P6 is outputting, wouldn't it have no where to go and therefore 0v? First it would have to go the wrong way through my IR LEDs, and they still work so I don't think that's happening. Then it would have to go into p9 and p7 which are outputs, and outputting. Then besides all that, wouldn't my oscilloscope register one of the two signals as a negative voltage, not just add them together? I'm thoroughly confused.
    Later, I'll see if I have an appropriate diode to protect the LEDs from the prop chip (if I have two appropriate diodes, I may put one on each LED so they're protected from each other as well). That should circumvent any misunderstanding I may have about how the pins are being manged. It could be that duty mode on the counter (%00110) controls outa[APIN], and not dira[APIN]. It does make some sense that instead of each cog verifying both outa and dira are high in that cog, one cog could set dira high, and another could set outa high. Maybe that makes more sense. But that would not explain a voltage level > 3.3v to me.
    Time for lunch.
    edited 2013-11-17 11:28
    Just a quick update while I process.
    I spent some more time with my oscilloscope this morning. Before I bothered looking at adding to the circuit, I decided I should make sure there is nothing more to learn from what I have. I decided to get rid of the second LED, and hook things up just like the PE labs example. Then I ran the pekittest code I linked earlier with the second LED stuff commented out.
    The receiver is on channel two, which is disabled above. The distance output is telling, as you move your hand closer, it the prop (usually) sees it getting closer until around 170/256, any closer and it still detects it, but indicates it's farther away than it is. (hard to see in a picture, but the LED appears bright, then dims out)
    Just to see it, I ran the basic detection routine from my pasm code.
    Notice, without the duty mode counter enabled (still grounded at P6) the oscilloscope only sees a little more than a volt at the LED.
    With the duty mode counter enabled:
    No light, no detection, plenty of volts.
    Out of curiosity, I decided to run the pekittest again, and this time take a look at it with my multimeter. It saw a peak voltage of 1.6 volts, and a minimum voltage of 0.6 volts.
    Clearly my high school education is not cutting it here. Does anybody have any reading they'd recommend for some general electrical background? Am I using my oscilloscope incorrectly? I have both my probes grounded to the big "ground pin" in the corner of my development board. The readings are the same with only one and either probe; both of which are set to 1X "impedance" (I think that's what that is).
    PS: I think the duty mode must modify outa, not dira. So it doesn't toggle from input to output; it just toggles the output on and off, and all pins are always inputs except while they are high and will complete a circuit despite having been set as an output. I wouldn't be terribly surprised if I was wrong; but that's my current thinking.
    1024 x 768 - 77K
    1024 x 768 - 72K
    1024 x 768 - 89K
    1024 x 768 - 80K
    edited 2013-11-18 11:18
    A little more stream of consciousness:
    I was looking over the PEkitLabs example for IR distance detection, and noticed I had miss read the resistor value. I had a 10k ohm resistor between the prop and LED (the object detection lab uses a 10K ohm resistor), and it should be a 100 ohm resistor. I switched in the right resistor, and now the minimum distance reading I get from the example code is 148/256; as apposed to the ~170/256 I was getting earlier. I experimented with this exact code and setup shortly after I first got the propeller, and I'm pretty sure it worked all the way down to single digits. Maybe I have damaged the LEDs; so they don't work as well at low voltages. Maybe.
    PEKitLabs-v1.2.pdf (duty mode is detailed on page 135, and the IR distance lab starts on page 156)
    I also found this AN001-P8X32ACounters-v2.0_2.pdf which details the counters.
    I looked through the propeller manual for counter details too. However, nowhere did it clearly state whether the APIN is being toggled on off by modifying outa or dira. I'm pretty confident it modifies outa, but it would be nice to have a definitive answer on that (I suppose I could write some code to figure it out, but that seems like something worth noting somewhere).
    I discovered yesterday that if I switch the duty signal from the p6 "the ground pin" and connect the APIN to an LED, the LED lights and dims. So clearly it generates an output voltage. So I don't understand how the PEkitlab works.
    To test my next assumption, I hooked up pin 25 to an LED and had it turn on. Then I added pin 24 as an input, and tried grounding the LED to it. No light. But the oscilloscope sees the voltage jump from a little over a volt to a little over 4 when I try to ground the LED with a prop pin.
    p25 &#61609;&#9472;&#9472;&#61629;&#61630;&#9472;&#9472;&#61606;&#61607;&#9488;
    p24 &#61609;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    pub main
      dira[25]~~    'p25 set to output
      outa[25]~~    'p25 set high
      dira[24]~     'p24 set to input
      repeat        'repeat forever
        next
    Now I'm really lost. I'm not sure if I'm missing something about how the pins work. Or if I just need to spend some time reading about electricity. I definitely don't understand the readings I'm getting on the oscilloscope. Or what the multimeter is telling me.
    I could just bail on trying to understand how this works, and add a second pin to the circuit for the second LED. Then I could run them both like the other doesn't exist. Or I could try experimenting with adding some diodes to the circuit just to see what happens. I should probably look for some good background reading on electricity and circuits and stuff.
    edited 2013-12-06 17:40
    So the competition is tomorrow, and I haven't made any progress. I didn't expect to have the robot finished, but I was hoping to get a prototype block sensor rigged up.
    I was feeling the need to educate myself a little, and stumbled across this site: http://www.ibiblio.org/kuphaldt/electricCircuits/
    which has 6 free textbooks, and decided I would read the first one.
    As far as textbooks go, it was great.
    For the exercise, I decided I would make myself some sort of note sheet, and ended up just writing stuff down
    in a .spin file so I could use the circuit "characters" instead of having to draw circuits somehow.
    ElectricityNotes_DC.spin
    I'm sure it's full of spelling errors, but I thought I would share anyways.
    While an enlightening and worthwhile project, I'm still totally lost on my block sensor.
    Rather than dive back into my original code, I decided I would try to write some bare bones PASM just to demo the main theory of operation. Unfortunately, It's not quite working either.
    {{ BLOCK SENSOR Notes
    PELab circuit
                       LED
           CTRB &#61609;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#61606;&#61607;&#9472;&#9488;
                  100&#937;    &#9474;
           CTRA &#61609;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
     Theory of Operation:
     Config CTRB to generate 38KHz signal
     Config CTRA to generate sweeping duty signal
     When CTRB is high, and CTRA is high, there is no current through the LED
     When CTRB is high, and CTRA is low, there is current through the LED and it should light.
     When CTRB is low, and CTRA is low, there is no current anywhere
     When CTRB is low, and CTRA is high, there will be voltage potential through the led backwards,
         but only a small amount of current (irrelevant) and no light.
    Block sensor circuit
                   100&#937;  LEDs
           Left  &#61609;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#61606;&#61607;&#9472;&#9488;
           Right &#61609;&#9472;&#9472;&#9472;&#61629;&#61630;&#9472;&#61606;&#61607;&#9472;&#9508;
      CTRB to generate 38KHz signal, alternating pins:  Left for 2ms -> rest period -> Right for 2ms
      CTRA to generate duty signal, starting at 99.9% and stepping down after each Left, Right CTRA pin cycle
    CON
    PUB main
      cognew(@start, 0)
    DAT
                  org 0
    start         mov temp, #1
                  shl temp, #9
                  or  dira, temp                    'set p9 to output
                  shr temp, #2
                  or  dira, temp                    'set p7 to output
                  'config duty signal
                  shr temp, #1                      'set temp to P6 pin mask
                  mov frqa, #0                      'clear frqa
                  mov phsa, #0                      'clear phsa
                  mov ctra, G_cntr                  'config CTRA for duty signal
                  or  dira, temp                    'set p6 to output
                  'LEDs
                  mov frqb, FReQB                   'load frqb
    reset         mov duty, top                     'set/reset duty signal
    loop          sub duty, dinc                    'dinc duty signal
                  cmp duty, #0  wz                  'is duty signal 0%
            if_z  jmp #reset                        'if Z, reset duty signal
                  mov frqa, duty                    'set duty cycle
                  mov ctrb, Left                    'left LED on
                  'jmp #loop    '<- works up to here
                  mov time, cnt
                  add time, delay
                  waitcnt time, delay       '<-wtf?
                  jmp #loop    '<- doesn't work
                  mov ctrb, #0                      'off
                  waitcnt time, delay
                  mov ctrb, Right                   'right LED on
                  waitcnt time, delay
                  mov ctrb, #0                      'off
                  waitcnt time, delay
                  jmp #loop
    Left          long ((%00100 << 26) | 9)
    Right         long ((%00100 << 26) | 7)
    G_cntr        long ((%00110 << 26) | 6)
    top           long 4294967000
    FReQB         long 2040109
    dinc          long 1000
    delay         long 16000
    temp          res 1
    time          res 1
    duty          res 1
    It just hangs up on the first waitcnt. So to experiment, I wrote this[below] code. But to my surprise, it works as expected.
    CON
    PUB main
      cognew(@start, 0)
    DAT
                  org 0
    start         mov temp, #1
                  shl temp, #9
                  shr temp, #2
                  or  outa, temp                    'right light on
                  or  outa, left_pin
    loop          xor outa, temp
                  mov time, cnt
                  add time, delay
                  waitcnt time, delay
                  xor outa, left_pin
                  jmp #loop
    left_pin      long |< 9
    top           long 4294967000
    FReQB         long 2040109
    dinc          long 1000
    delay         long 80000000
    temp          res 1
    time          res 1
    duty          res 1
    What gives?
    If I run the code up to where it says "<- works up to here" I get one dimming light. So I'm fairly confident the circuit is okay as is.
    Also, I'm a little confused about the "dira" register. Why is there a "dira" register? It seems like you could get away with just "ina" and "outa" registers.
    If you set outa[pin]:=1, pin==output and ina[pin] always == pin state (isn't that how "ina" works anyways?)
    Blarg.
    edited 2013-12-09 18:05
    Very curious...
    This code, does not work as intended (LEDs alternate, but duty cycle never changes [stuck at 99.9%]):
    CON
    PUB main
      cognew(@start, 0)
    DAT
                  org 0
    start         mov temp, #1
                  shl temp, #9
                  shr temp, #2
                  'config duty signal
                  'LEDs
                  mov time, cnt                     'set up time delay
                  add time, delay                   '   " "
                  waitcnt time, delay               'delay
                  mov ctrb, #0                      'off
                  mov ctrb, #0                      'off
                  jmp #loop                         'loop
    top           long 4294967000
    FReQB         long 2040109
    dinc          long 1000
    delay         long 80000000
    temp          res 1
    time          res 1
    duty          res 1
    However, If I comment out all the waitcnt commands, my sweeping duty signal comes back.
    Wow, as I was writing this, it occurred to me to try shrinking my delay periods down closer to where I expect them to be in the final code, which is around 2ms (vs the 1s in the test code), and it appears to be working. If only I knew why.
    update:
    I know why. I still had the waitcnts commented out :nerd:.
    So never mind basically.
    With waitcnts, I have control of LED timing, but no sweeping duty signal. With no waitcnts, I get a sweeping duty signal, but I "lose control" of the LEDs.
