increment or decrement led oscillation speed
Hello All,
I am new to micro-processors and had a question about the propeller in Spin. I am working through the PE Kit and wanted to try a combination of lessons into one project. I have 2 leds oscillating and am trying to set the oscillation between 1 second and 10 seconds. The code I wrote kinda works but when the push buttons are pressed the oscillation speed changes more than by 1 second and the code seems to have to wait for the current code to finish before the increment or decrement takes place. What I would like to have happen is the oscillation speed change by one second incremently or decremently by on second each button press. Also I would like for the pressed button to change the oscillation speed immediately. What I think I need to do is use cogstop then cogstart or cognew to initiate a new cog every time one of the push buttons are pressed and pass the parameters between the methods I write. Am I on the correct path?
Here is the code so far:
CON pin1 = 0 pin2 = 1 pb1 = 21 pb2 = 20 VAR long stack[20] long speed PUB Main cognew(Blink, @stack[0]) cognew(Button, @stack[10]) PUB Blink dira[pin1..pin2]~~ outa[pin1..pin2]~ speed := 1 repeat !outa[pin1] waitcnt(clkfreq * speed + cnt) !outa[pin1] !outa[pin2] waitcnt(clkfreq * speed + cnt) !outa[pin2] PUB Button repeat if ina[pb1] == 0 waitcnt(clkfreq/6 + cnt) speed ++ speed <#= 10 elseif ina[pb2] == 0 waitcnt(clkfreq/6 + cnt) speed -- speed #>= 1
Hard to tell from what you posted but it looks like you are not de-bouncing the push buttons in your code. That will cause the speed to be incremented more than once. Can you post all your code between {code} and {/code} lines but use the square [ ] brackets instead of the curly { } brackets?
Thanks for your reply. I am not sure how to correctly copy and paste the code I wrote into the Blog Post. I am also not sure what you meant by; "Can you post all your code between {code} and {/code} lines but use square [ ] brackets instead of the curly { } brackets."
What is {/code} is that short for "not code"?
Could you write a short example please?
I read in the PE manual the push buttons included with the PE kit don't have to be de-bounced. I am not sure if the author meant the simple programs written don't need to be de-bounced or it the push buttons themselves don't bounce.
I am not sure how to de-bounce a micro-controller circuit, (I usually use a 555 in mono-stable mode). I messed around with controlling switch bounce a little but I am not sure my approach was correct. Not sure weather to use REPEAT WHILE or REPEAT UNTIL in combination or some WAITCNT commands like WAITPEQ. Below is some of the code I wrote to use on my propeller demo board that worked with a case statement: The code is suppose to turn on the leds one at a time in secession without switch bounce. I tried to fix all the indentation on the code in the repeat portion to make it easier to read, I hope that helps until I learn the correct way to post code.
I was able to solve my original problem by taking a different approach. I would post my solution but it involves objects and I don't know how to post all the objects that were used to make the whole thing work. The solution I used only uses one pin (ina[pin]) instead of two (like in the increment and decrement code.) I would still like to solve the increment and decrement code though. I don't gain anything by not learning.
CODE:
