Help with RC plane
I'm building a foamy RC plane and I'm having some trouble. I have three parallax standard servo's, A parallax GemFan 30A ESC, A parallax Brushless outrunner motor 1,000kv A Tactic 2.4GHz SLT TR624 6-Channel reciever & the 4 channel transmitter it came with. and as a power source I'm using A 12v AC/DC adapter just to test the set up before I buy the battery. My problem is, when I start the motor it runs fine throttles good and everything is fine. when I start to move the servo's the motor dies out and I have to reset my input to zero and start again. Idk what I'm doing wrong. Are my servo's drawing too much power? is there something I'm missing. If any one can help me out I would really Appreciate it. As far as the lay out... My power source is basically a 12v ac/dc plug that i cut the end off of and connected the power and negative to the Black and red cables on the ESC then I have third multiwire connector connected to the reciever in the proper channel for throttle. the servo's are all connected to their respective channels as well.
Parallax standard servos are not for foamies : they are too heavy (44 g ! ) and i think that they draw too much power (the limit may be 1or 2 amps with the BEC line) .
Look at Turnigy 9 gram servos (Hobbyking store) or Hitec HS55.
What foamie plan are you using ?
Two foamies for beginning : Super easy or Nutball
Look also here:
http://www.rcgroups.com/foamies-scratchbuilt-428/
Cats
easily pull dozens of amps. LiPo batteries are extremely powerful and not easily substituted with
a cheap PSU.
Cats92 is is probably right too but the Parallax servos shouldn't be causing much trouble on your bench setup (but this depends on your power supply).
I've had lots of trouble when testing motors from a bench top power supply. Even though the power supply should have been able to supply the required power, it would still have trouble with sudden power changes (starting the motors).
A good battery pack eliminated these power issues.
I buy LiPo packs from HobbyKing. I try to find the size of pack I'm after in the USA warehouse first since the shipping is so much faster. While you're getting your LiPo packs, buy one of those bags for charging LiPos. The charge bags will help contain any fires (I've charged a lot of LiPo packs myself and I've never had a fire problem). Apparently the smell from a LiPo fire can be really bad you you want to charge some place that won't smell up your home (though I still charge my batteries in basement, I plan to move the charger to the garage).
Here's a link to the 9g servos at HobbyKing Cats92 mentioned. I have some other servo links in post #10 of my index (see signature).
