Long Cheap Servo Cables
Female-female three-conductor cables, so you may occasionally need some male/male headers to cover every possible connection. Reprap, servos, many uses. Non-standard colors compared to servo cables, just be careful. Wire size in photos looks to be bigger than most servo cables, which is good for longer runs, less voltage drop.
$4.50 for 10 pieces, 70 cm (~27 inches) long. Free ship. Not real sexy, but cheap & useful. Just order some now, you'll use them sooner or later. Can't go wrong for 45 cents each!
http://www.ebay.com/itm/GeTech-5pcs-10pcs-70cm-3pin-Female-Female-Cables-Jumper-wires-/261261804974
Tell 'em erco sent ya!
Jeff
Cabling is one place where I don't think it's wise to go too cheap.
