OSHPark price VS SeeedStudio price
Maybe I am doing something wrong, but I have a board that is 3.688" square and I have finally finished the design using Diptrace. I went through the steps to order via OSHPark and at the end, the price is $68.20 for 3 boards. Then, I checked Seeed's board cost since I am shopping around for a good production run price after test boards are tested. Amazingly, Seeed's price is calculated at $20.90 for 5 boards!?!?! Am I missing something here or does that sound correct?
Also... On Seeed, the file extensions don't match according to what Diptrace outputs as a Gerber file and what Seeed is needing. Supposedly they work properly since OSHPark can process the board design automatically through their site. Do I just need to change the file extensions manually?
I always use the FREE software called GC-Prevue to examine the Gerber files my PC Board CAD program generates. See:
GC-Preview
You should at least be able to get your board files in G-Code so you can shop around for the beat deal.
Here is an example of a board I use.
It is about 1"x2.25"
It's relatively complicated and very dense.
I buy them in quantities of 1000
The cost is about $0.28us each.
The setup was a one time charge of about $250us
OK, this is more than what you would want to pay for a prototype.
What I'm saying is the first board cost $250.
So $20 to $50 don't look two bad.
However, that $20 to $50 better at least supply you with G-Code files so you can send them to a production board house.
Anyway GC-Preview is a great way to prove your CAD software is working correctly. A second set of eyes so to speak.
Duane J
You can change that in DipTrace. I output files to match Protel naming because that's what we (EFX-TEK) used before. I have never had any problems submitting files [to the services we use] from DipTrace that were named using my customized extensions. Find out what Seeed wants and rename your Gerbers accordingly. You can even setup DipTrace to automate that process for you.
The attached screen shot shows how I setup my Gerber output in DipTrace.
BTW... you know you can order from inside DipTrace, right? Here's a tip: they have a minimum charge. Spin the quantity box up (from you needed count) until it changes. I recently needed five PCBs but got 16 for the same price. Not as cheap as the sources you cite, but then, I value my time.
Edit: It looks like Seeed wants Eagle files -- you can find the extensions on this page: http://www.protoexpress.com/content/gerber_extensions.jsp
I usually use OSH Park for small boards.
I haven't used Seeed Studio but I have used Itead Studio. While Itead's price was about a fourth of the OSH Park's price the boards from OSH Park were much higher quality than Itead's boards.
If you don't use OSH Park this time, you ought to at least try them when you have a small board you want made. I think you'll see a difference in the quality.
Other pros:
Made in USA, Purple mask on black pcb, gold enig, Internal cut out, Faster turnaround at about 9days, Smart online ordering website.
Something is wrong, make sure you don't have any via or even top silk outside of your intended board area.
What is so good with oshpark is that you get views of silk and copper etc right at the website so you can catch that error.
Plus at the end just before placing the order, the website says what your board size is did that match up with 3.688"?
25.4mm * 3.688in = 93.68mm.
I asked them if 3.68" was inside the 10*10....
EDIT *** After looking closer, their measurements are in CM, not MM
The board is 3.688" square which is 13.601344 square inches. At $5 per square inch this comes to $68.01. So there is a discrepancy between the size Diptrace is claiming and the size OSH Park is computing but only a very small one. There's only a 19 cent difference between the two prices.
I like OSH Parks boards but they get pretty expensive fast if your board isn't small.
My 1/2" magnetic encoder boards cost $1.25 for a set three (including shipping). For really small boards, OSH Park's price would beat Seeed's price (unless you panelized your boards to fill the 25mm square).
If you did mean 3.688" x 3.688" when say so, I have heard the above term used sometimes but should be outlawed as to no be confused with 3.688 square inches.
I just took a look at the entire cycle. 22 days from order to arrival at my door.
If there existed a really fast, good and cheap PCB manufacturer, everyone would be using it.
- Fast
- Good
- Cheap
Choose any two.
