My ankle hurts I think I will build a new one — Parallax Forums
jdoleckijdolecki Posts: 726
edited 2013-10-28 14:52 in Robotics
I have decided to build a humanoid.
Im getting rid of or disassembling all my rolling and small robots.
Here is the first part the ankle.
The motors a surplus science store. 10 dollars
The ankle joint is a rod end, pitch, roll and yaw all in one simple package. The finish rod end will be a aluminum one to reduce weight.
http://youtu.be/1fgGabc9aYU
  • DiverBobDiverBob Posts: 1,124
    edited 2013-10-21 08:06
    Looks like an interesting project!
    edited 2013-10-21 08:48
    Pretty cool, nice ball joint and two DOF has interesting possibilities.
    Makes me wonder about using a 3-servo Delta robot arm as a leg. Hmmm. Martin_H?
  • jdoleckijdolecki Posts: 726
    edited 2013-10-27 18:28
    Worked on the humanoid ankle this weekend. Got the aluminum rod ends and the aluminum tube I'm using for the frame. Cut the other foot pad out. Made a bunch of brackets to mount the motors (still not finalized) it will probably all change after the first real test anyways. The long actuator tubes will get shortened anyways. Hopefully I can have both ankles done this week. Working on the knee design now to.
    1024 x 765 - 96K
    1024 x 765 - 101K
    Please note the shameless Parallax plug sticker on the side of the leg. How about a HB 25 motor controller in 24 volts.
