GPS and rare earth magnets — Parallax Forums
Andrew2010Andrew2010 Posts: 4
edited 2013-10-17 10:34 in Accessories
I am planning to use rare earth magnets to mount a propeller based GPS setup on my kayak. I am wondering if the magnets are likely to cause problems with the GPS sensor?
The magnets will be around 5cm below the GPS sensor.
    edited 2013-10-11 17:27
    The GPS receivers do not use magnetic fields to determine location. They receive RF signals from satellites so having a magnet nearby should not be a problem.
    Although, Andrew2010 is "down under" in Sydney, where everything happens backwards relative to what we think is "normal" in our Northern hemisphere. For all we know, a strong magnet near a GPS receiver may trigger a wormhole or other cataclysmic event.
    Godspeed, Andrew2010! :)
