How to measure water hardness electronically
Was wondering if there is a sensor made for this sort of thing or if something could be made "home brew"? For those that are versed in this matter- school me please. Was thinking of building a device that measures water hardness before / after water softener.
Thanks but yes I already found that.
It might be possible to perform some sort of spectroscopy on the water but I don't know what wavelength you'd want to use (this can be looked up of course).
http://www.hannainst.com/usa/prods2.cfm?id=042005&ProdCode=HI%2098202
http://www.tdsmeter.com/products/zt2.html
http://www.tdsmeter.com/products/ec3.html
Thought it might be a neat project with a Prop, some sensors and an LCD display...
Thanks Don. I didn't know about those.
I wonder how they work.
http://www.ausetute.com.au/waterana.html
question (or an amalgam?) and a membrane permeable only to the ions of interest. The potential of such an
electrode has a concentration dependent term - in other words the potential is a proxy for the log
of the equilibrium constant for the reaction M+(aq) + e- <--> M(s)
The tricky bit is finding a suitable membrane for a particular metal I believe.
Wikipedia seems to bear out my memory here: http://en.wikipedia.org/wiki/Ion_selective_electrode
I suppose one could set up a device that cleans the electrodes before each reading, but it begins to get complicated.
As you can see above, the use of a membrane to isolate just the ions you want to quantify may be necessary, and you still have the problem of keeping the electrodes clean.
Jim
Jim
Seems like it would be quite an interesting DIY project.
