Card Edge Prop Board
tonyp12
Quickstart kind of set the new standard,
But once you want to mix and match small add-on boards you run out of Vcc and Vss pins.
Hence I here introduce the new 6P add-on board standard.
The 6 slots on the left have P0 to P23 brought out, good for SPI or any generic I/O.
Pinout: 3.3V, Gnd, IO1, IO2, IO3, IO4
If you want to secure the board down, add a solder glob to the round pad shown, it will also add Vin to the add-on board. (sorry there are no 7P connector)
The 3 slots to the right are for I2C add-on boards.
Pinout: 3.3V, Gnd, SDA, SLK, IO1, Vin
If you need 6-8 GIO, Boards that bridge two connectors will be available.
The board is 100x50mm, this is the connector it uses:
http://www.digikey.com/product-detail/en/009159006501906/478-7771-1-ND/3721598
Though a top-mount version is coming out soon, I think the through hole I use will add strength.
Here is a Phono Connector Video board, it does not use the left part of the max width.
Res values takes in account that main board have 100ohm on all pins.
Through Hole prototype boards will be available 4boards for $10.
1A Stepper (or dual DC motor) driver board.
Texas Instrument digital audio DAC PCM5100A 16-32bit stereo,
2.1VRMS ground centered outputs to a 3.5mm connector
Audio UV meter or KnightRider, CharliePlexed.
I2C Real-Time-Clock. Battery will last 15 years, saves you from having to re-program correct time between non-use.
Board-width of 25mm is the Maximum for I2C 6P standard
MicroSD card + 32KB SPI Ram, the shared CSelect is inverted for the Ram with the use of a npn-mosfet.
Wow dude.
Looking forward to see the whole line up.
Very creative , great design (form follows function) and will have much appeal to many.
sm
