Card Edge Prop Board — Parallax Forums
tonyp12tonyp12 Posts: 1,951
edited 2013-10-19 16:24 in Propeller 1
Quickstart kind of set the new standard,
But once you want to mix and match small add-on boards you run out of Vcc and Vss pins.
Hence I here introduce the new 6P add-on board standard.
The 6 slots on the left have P0 to P23 brought out, good for SPI or any generic I/O.
Pinout: 3.3V, Gnd, IO1, IO2, IO3, IO4
If you want to secure the board down, add a solder glob to the round pad shown, it will also add Vin to the add-on board. (sorry there are no 7P connector)
The 3 slots to the right are for I2C add-on boards.
Pinout: 3.3V, Gnd, SDA, SLK, IO1, Vin
If you need 6-8 GIO, Boards that bridge two connectors will be available.
The board is 100x50mm, this is the connector it uses:
http://www.digikey.com/product-detail/en/009159006501906/478-7771-1-ND/3721598
Though a top-mount version is coming out soon, I think the through hole I use will add strength.
Prop6P_Board.jpg?psid=1
    edited 2013-10-11 15:49
    Tony, Nice layout. Looks like a new twist on the old SpinStudio boards. I am actually surprised that someone hasn't made a QuickStart add on board that broke things out in a similar manner. That style of setup would be good for an educational kit where all of the peripheral items are designed in a standard form factor. Just plug n go!
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-10-13 13:59
    I will create bare boards in various sizes (Diptrace) so you can put a project together fast and then you order 3 boards from OshPark for around $5 each.
    Here is a Phono Connector Video board, it does not use the left part of the max width.
    Res values takes in account that main board have 100ohm on all pins.
    RCA_Card.jpg?psid=1
    Through Hole prototype boards will be available 4boards for $10.
    6P_Proto.jpg?psid=1
    1A Stepper (or dual DC motor) driver board.
    6P_Stepper.jpg?psid=1
    edited 2013-10-19 15:15
    4 new boards done, by the time I'm ready to roll-out the main board for sale at least 20 add-in boards will be available.
    Texas Instrument digital audio DAC PCM5100A 16-32bit stereo,
    2.1VRMS ground centered outputs to a 3.5mm connector
    6P_Audio.jpg?psid=1
    Audio UV meter or KnightRider, CharliePlexed.
    6P_CharlieLED.jpg?psid=1
    I2C Real-Time-Clock. Battery will last 15 years, saves you from having to re-program correct time between non-use.
    Board-width of 25mm is the Maximum for I2C 6P standard
    6P_I2C_RTC2.jpg?psid=1
    MicroSD card + 32KB SPI Ram, the shared CSelect is inverted for the Ram with the use of a npn-mosfet.
    6P_uSD%2B32K.jpg?psid=1
  • StephenMooreStephenMoore Posts: 188
    Tonyp12:
    Wow dude.
    Looking forward to see the whole line up.
    Very creative , great design (form follows function) and will have much appeal to many.
    sm
