Improving GPS connectivity indoors
Hi,
I have a PMB 688 GPS module that I'd like to use on my Stingray. I have it connected, I have written the code, and it works - sort of.
I have the optional external antenna, and when I connect that and hang it (the antenna) out a window the PMB 688 acquires sufficient satellite signals to get a position fix after a minute or two. The problem is that if I disconnect the external antenna and rely on the PMB 688's internal antenna, I never acquire sufficient satellites and so never get a position fix when the module is indoors (I haven't actually tried the internal antenna outdoors yet). While it's fine to hang the external antenna out a window to test the hardware and software, it's not really what I was looking for... The external antenna comes with a 3 metre cable, but I was hoping my Stingray would be a bit more mobile than that!
I have tried initialising the PMB 688 with the ECEF co-ordinates of its location, but that doesn't help.
Does anybody have any ideas on how I might improve the PMB 688's ability to see what I guess are weak signals indoors? Would a different GPS module be any better (the VPN1513 for example)?
The difference between these two GPS units was night and day. The one from Parallax took over ten minutes outside in the open to get a lock while the one from SparkFun would get a lock anywhere in my house almost instantly.
All I can say is to try to find out from others what GPS module currently sold does well indoors. I'm pretty sure the ones which work well indoors are going to cost more.
I should clarify "works well indoors". Even if a GPS module can get a lock indoors, it's likely not going to be as accurate as when operating outdoors. GPS are generally intended for use outdoors. I doubt GPS will offer much assistance to indoor navigation.
I did the same, but still no satellite lock. I understand they're primarily outdoor devices - I just wanted to play indoors. My Stingray's not going to spend a lot of time outdoors...
Thanks Duane and Chris - I may just give up on the idea of GPS indoors.
http://upstatecastle.com/
http://www.nytimes.com/2013/04/23/booming/their-castle-could-be-yours-for-under-a-million.html?pagewanted=all&_r=0
