Brainstorming for all you Engineers out there
NWCCTV
OK. I have an idea for something but I do not know how to make it work. I figured with all the Engineering brains within the Parallax community someone can come up with a solution for me.
I have a telescoping tri pod. I want to disassemble it and use one of the legs. Here's the tricky part that I am having trouble figuring out. I need the telescoping to be done using either a Servo, Stepper motor or just a plain old DC motor. Whatever I use needs to be as inconspicuous as possible. The legs are hollow so I can run cable through them. I have been thinking of a pulley type setup but I am just not sure how well(or how!!!) that would work. Suggestions and diagrams are all welcome. Thanks all.
Does something like this do answer your question?
http://www.youtube.com/watch?v=46dZln2JgJE
Yanomani
BTW, the only weight this mechanism has to support is that of the antenna itself. If you want your tripod leg to support more weight, this may not be the best choice of mechanisms.
There is a spool inside it, with an helicoidal track crafted at its outer surface. A semi-rigid steel cable is wound, following the helicoidal track, and fixed thru a hole, at the track start, by means of a short zig-zag path, crafted inside the spool.
The other end of the cable is fixed, sometimes by a welded screw bolt, that is fixed to antenna's top end, by means of a nut.
A DC motor, by means of a pinion-based reduction mechanism, drives spool's rotation, CW and CCW.
I'm searching for some good diagrams, but it seems I'm out of luck till now!
Yanomani
Phil
He he he
It seems that the antennas I'd saw, dismantled, are many times older than the ones you saw!
I'm becoming older and older, each day!
Yanomani
EDIT: Does anyone know what the metal spring strip is called and or where to get it?
Just thought of something. I wonder if Fish Tape would work???? I would need a pretty powerful motor though.
Are you talking about a constant force spring?
http://www.mcmaster.com/#constant-force-springs/=or7jod
Even ball and roller bearing based mechanisms do fail, as operational cycle counts and dust (sand, rust) particles piles up inside.
The main concern, as Phil had expressed, is the amount of force to be exerted on the recoil/extend movement.
Multi way threaded axle solutions, ball bearing driven, can be crafted to handle a lot of torque and speed, but they are in no way shorter than half the total maximum extent amount.
And to realize its maximum extensibility of movement, they depend on crafting the ball bearing driver as part of motor's rotor.
Then, some part of motor's lenght must be subtracted from the required linear movement.
That was the reason for the above expressed shorter than half telescopic leg lenght movement limit.
Direct motor drive is possible, where extending forces are not beyond certain limits.
Concentric reduction mechanisms will deal with the amount of torque needed, at the cost of complexity (cost), volume and speed.
All of the above will need some electric current sensing, to limit (and protect) motor driving (even for steppers), as it reaches leg full extending or recoiling and to allow some room for mechanical stalls.
I believe that are not simple solutions to that kind of problem.
Yanomani
These can withstand up to 3000 N, max. 250 mm/s, but they are huge!!!
They can be found at:
http://www.shsitalia.it/
Yanomani
EDIT: I am also looking at extra strength zip ties. I just need to find one long enough.
EDIT2: After looking at the link @ElectriAye posted, I may have the solution. A tape measure!!!!! Or I may just get some of that material. Thanks all. I think I have some where to start now.
NWCCTV
You has just banished my wildest thoughts!:frown:
I just now remembered, that even sturdy and speciality crafted tripods will fail, till being wrecked out, under certain circunstances...
Yanomani
http://www.hizook.com/blog/2008/12/22/geosystems-situational-awareness-mast-aka-zippermast
http://books.google.com/books?id=VJMhAQAAMAAJ&pg=PA301#v=onepage&q&f=false
How cool would a robot with hydraulics be?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14054
[video=youtube_share;vvaYTVBHHYU]
I am using Magicdraw to use BuzzToys MyroMagic, Mode C to communicate with the Scribbler Rover in Dr. Russell Peak's SysML class at Georgia Tech. Lately I have become fascinated with the Raspberry Pi and would like to have Mode C download the code to the Pi instead of the Scribbler Rover. I called Parallax and they thought you might be responsible for writing the code for communicating with the Scribbler. How difficult would it be to modify the software to send code to the Pi?
Mr. Pilgrim can be reached at: propeller AT phipi DOT com.
That would be preferable rather than taking this thread off-topic.
or what about a rack and pinion setup?
