6 wire phone jack?
Something is just not clicking for me... I am trying to locate a right angle 6 wire phone jack that is surface mount with solder retention and does not require any holes to be drilled in the PCB. I have been searching all over Digikey and have found this : http://www.digikey.com/product-detail/en/0855025007/WM3546CT-ND/2405745
Is this a 6 wire phone jack plug? What is the 6p6c? From what I gather, it means 6 positions, with all 6 with contacts in them... is this correct?
We always bring it back to RJ11 so you can use standard pre-made cables and patches .....
RJ12 crimps with standard crimp tools. It putting in placed trough the locking lip
You can use standard RJ11 patch and coupling devices with RJ12 , but not the other way round
http://www.mouser.com/ProductDetail/Molex/85513-5002/?qs=%2fha2pyFaduikdRnLaL3shAQxtW4zSBwt9i32RLDmj%2fQ%3d
Try to follow the inner-pair standard,
and if you circuit have a signal that is "optional" use the most outer-pair wires for this so regular 4wire cord can be used when this signal is not needed.
