Where to get 100 enclosure cases made ?
Bean
I have a project that requires and enclosure case.
I have a 3D model and have printed it on my 3D printer.
Problem is I'm going to need at least 100 of each half and I don't look forward to printing them myself.
Does anyone know of a company that can made them from my 3D model for a decent price ?
Each half is about 4"Lx3"Wx0.75"H the material doesn't really matter as long as it can survive a 6 foot drop without damage.
Bean
Bean
https://www.hammfg.com/dci/mods
You have two rather large surfaces that can be 'sandwiched' with the board inbetween via standoffs. The other 4 side can just be keyed into the top and bottom. The ends can all be either butt glued with conventional acrylic glue technique or mechanically keyed somehow.
For build a box, it is difficult to be sheet materials for being cost-effective. Buying spools and spools of 3-D plastic may really cost a lot more.
http://www.123dapp.com/about3D
dgately
Bean
You can upload the 3d model and in short time get an evaluation of feasibility, and price, choosing material and quantity. 100 are probably on the low side, but worth a (free) check.
You could also check, still for free, shapeways.
Massimo
Can you post your STL file? Let's see exactly what we're looking at.
I don't have any photos that I took myself so this one will have to do for now. It is 100% laser cut and assembles with eight screws.
That is quite nice! And 'very clever the way you handled the stacked laminations.
How did you manage to screw it together? Towers?
Massimo
Here is a cutaway view;
Radiation detector - http://excelphysics.com/collections/frontpage/products/apoc-basic-kit
Looks neat!
Try and get hold of Jim Fouch (forum member in PA, I believe) He's been to a number of Jeff's Expos. He's launching a online service to create laser cut cases. He may have some ideas or be able to help you out.
I'm not sure how well any of the laser cuttable materials will hold up to a 6 foot drop but Jim may have some ideas.
If I find his contact info, I'll send it to you in a PM but a PM to Jim might work too.
Cast acrylic, the only type I use, is significantly more durable and much less brittle than the standard extruded like what you would get at a home improvement store. Of course it depends upon what the case is hitting after falling 6 ft. A 6ft drop onto a wood or carpeted floor I am sure would be fine. Dropping onto concrete would probably result in at least a chip if it doesn't land flat - but I think that asking an electronic device to survive a 6ft fall onto concrete is a little much unless it is designed for extreme service.
Here is one half, the other is very similar.
Bean
Wow, That is great.
Could you give me an idea about how much ($) these cost is I wanted 100 of them ? You can send me a PM is you want.
Bean
PM sent.
Ideally, it would be handy if you could use vinyl sheet plastic, but I am uncertain that this will play nice with a laser cutter. And it may be more difficult to source.
Thanks.
Great stuff.
FYI, surviving a 6 foot drop onto concrete is a pretty common standard for small and/or portable electronics. Cell phones are tested in this manner (by makers and users, LOL). Many of the smaller devices we manufacture at work were put to this test by the designers but they are "normal service" products. One small device that goes into server rooms not only must be able to survive (as in still be functional) a 6 foot drop onto concrete, but the battery door must also remain attached (it's a snap close door, no screws)
In many cases, the battery is the most mass in the object and if that is very secure... not much is going to suffer.
One could laminate neoprene to the corners and sides. We need some flubber.
+1 Delrin is my material of choice on the laser when quality results matter. It has a good match of price, quality of cut, and durability. When thin ribs are cut into a piece, you can create flexible joints and living hinges.
