Capturing ZX81 video
blittled
The ZX81 was a marvel for its time since it generated its video using software and ttl logic rather than a separate video chip like other computers. It generated black and white output with a resolution of 256 x 192 in 8 x 8 blocks. They made 3 revisions and they cheated in the first 2 by having no back porch in the video output. In Revision 3 they had put it in since TVs were becoming more sensitive to the lack of a back porch. If you have a ZX81 or Timex Sinclair 1000 and hook it into a AV input to most digital TVs you'll get an almost unreadable signal. You need to find an old TV in a garage sale or goodwill store to get it up and running.
There are a couple of adapters for the TV signal out there but all require opening up the ZX81 and patching hardware into it. The ZX81 has a membrane keyboard that has become brittle with age and a custom chip that fails easily when static electricity hits it. For that reason I do not want to open my one working, never opened Timex Sinclair 1000 to be potentially damaged adding the mod.
Since the signal is only composed of black and white signals it should be able to be "digitized" by using a simple op-amp as a voltage comparator with its output connected to a switching transistor to convert it to logic level voltages. The Propeller should be fast enough to capture the pulses and recreate the bytes. The trick will be in locking into the vertical and horizontal syncs so timing will be correct. Once enough bytes are reconstructed it could be put in a video register for output to a TV to minimize delays. If possible the bytes should also be saved in a buffer so that a VGA driver can output it as well.
Is this a doable project or are there any other approaches of capturing the video output without opening my computer? Thanks!
Probably simpler to do it in hardware with a high speed comparator to detect the sync signal and a one shot (or 2) to modify the video signal. You could use a prop to modify the signal but you would still need a comparator or some other circuit to detect the sync signal.
The TS1000 was my first computer. And I remember it fondly.
I even have a couple around but the keyboards have failed on them.
One thing, don't forget that the output at the jack is modulated for TV channel 2 or 3. So you will have to demodulate the signal first before you can do anything with it.
If the keyboard works on yours then DON'T OPEN IT. That is a sure way to crack the fragile ribbon cable.
I would look at connecting the propeller to the edge connector and writing a video routine that sends the screen data to the propeller. You can intercept the video routine with code (that is how the pseudo hi-res graphics are done). It shouldn't be hard to send the video data to a Z80 port and have the propeller look for data at that port address.
Because of the strange way the zx81 does video, you might even be able to detect when the zx81 is doing video and sniff the data from the bus.
Bean
I have looked into the timing of the video on the bus and it isn't much better than the video stream. You have to capture data at two points with only enough time to do 8 pasm commands for each capture.
This may be a dead end but I am looking at using the Propeller through a Z80PIO so I'll post what I'm doing when I get somewhere with it.
Edit: I found a site that shows actual oscilloscope displays of ZX80 signals http://searle.hostei.com/grant/zx80/zx80ScopePics.html and if the ZX81 is the same my timing calculations have been way off. It looks like I could do 35-50 pasm instructions between captures which makes it possible to get the video as Bean mentioned.
Then you could have another cog read the video area of hub memory and display it on VGA.
You could also run the ZX81 in FAST mode with a display. So it would be four times faster.
Bean
@Bean you bring up an interesting idea with the Propeller as a pseudo ram pack. I wonder if the Propeller has the speed to do memory transfers. If you can't and have to pull video data from the address and data bus you will have to keep it in slow mode since none of those signals are present in fast mode.
Are you planning to have the prop read the data in parallel from the ZX video shift register? If so that makes things much simpler.
A single cog could use a waitcnt to monitor the load signal (IC9 pin 1) to synchronize reading the video byte as it is output to the video shift register. The bytes could then be written to hub memory where one of the video display objects (modified to suit) could access the data to display it.
There should be plenty of time I've been doing something similar with the sinclair spectrum, I'm using a 6.355mhz crystal x 16
I've got a bit of a description on the worldofspectrum website
http://www.worldofspectrum.org/forums/showthread.php?t=44669
I've just had a look at the link you posted and realised that I was assuming that the zx81 generated video in a similar way to the spectrum.
I've read through the description a few times and still don't quite understand whats going on!
If the z80 program reaches an address in screen memory the hardware forces it to execute nops and uses the refresh counter+the character byte to index a character look up table in Rom. When the refresh counters bit 6 goes low that signals the end of line and is used to signal the hysnc?
I'd always ignored the zx80 and zx81 I thought they were boring predecessors to the spectrum (my first computer) but reading that makes me want one!
It is only when the CPU tried to execute code from above 32K that the ULA takes control. (The lower 32K is echoed into the upper 32K).
So to start the display the CPU basically does a jmp to D-FILE+32K, this tries to execute the display file.
While the PC is above 32K any instruction with bit 6 cleared will cause the ULA to force a NOP to be executed.
At the end of each display line is a HALT instruction (which by chance has bit 6 set) when the CPU reads the HALT instruction is is executed causing the CPU to wait until the hsync signal causes a NMI interrupt breaking it free from the HALT state. (The hsysnc signal is generated by the ULA inself, not by the CPU at all).
While executing NOPs the I register is used along with the value in RAM to lookup the character bitmap in the ROM.
In all it is a pretty strange way to generate a display, but I guess in those days that is what had to be done to make such a cheap computer.
Bean
If you are into AVRs then there is all of this -
http://www.jcwolfram.de/projekte/avr/ax81b/main.php
He has done a whole load of stuff before this, and there is aSpectrum version too but that needs a CPLD.
There are translated pages about, it all a bit too early, on a Sunday, to find :-)
Alan
I've been reviewing my docs on how the video works and Bean's idea of pulling the information from the expansion edge connector may work, Just like the propeller the Z80 instructions take 4 clock cycles. During the period the video data is set up there are two points where the data bus needs to be polled. At the second clock cycle the character in the D-File is on the bus. This is needed since bit 7 tells if the character is inverted and bit 6 which works as Bean described. Then on the 3rd and 4th cycles during the Dynamic Ram refresh the 8 bit pattern for one of the 8 rows of the D-File character is present.
What I'm thinking of is have one cog to capture the D-File character and put it into a buffer. Another cog will take the D-File character and the 8 bit pattern and creates a buffer that the NTSC or VGA cog uses to display the output.
http://nocash.emubase.de/zxdocs.htm#zx80zx81keyboardassignment
I'm looking out for an affordable zx81 on ebay, so I might have need your finished project soon. No pressure
and
Maybe you can do something with the signal from the mic socket without having to open up the case?
could IC16 be a typo for pin 16 of the ULA IC in which case, according to this pin out, it is both the the video signal and the tape out.
EDIT:
I just looked at the schematic again and Basher is right. The Video and Audio use the same output with the exception of a couple of resistors, capacitors and a diode (USA).
You posted the link I started from in post 5 of this thread so I thought you would be working from the same schematic. The schematic link is “http://searle.hostei.com/grant/zx80/zx80.pdf”, and it let me download a PDF schematic of the ZX80 board. With that in hand it was just a matter of chasing back through some gates to see how the load signal for the video shift register was generated.
The circuit uses a 47pF capacitor, 2 nand gates from IC16 (74LS10), and 2 inverters from IC13 (74LS04). I am pretty sure the load signal could be generated using only a single 74LS10 and 2 prop pins (maybe even just 1 pin) in addition to the 8 data pins. Of course if you can spare a total of 14 pins on the prop no chips are needed, just "waitpeq" for the right condition.
it is possible to get a good capture by synching the PIC clock to the incoming video.
I managed multiple level grey scal ecapturwe by PWM addition onto the video signal during multiple fame captures. Slow - but energy efficvient
Pete
The ZX81 has a display 'buffer' pointer that is pointed to by a value (DFILE) at 4000h.
If the prop waits for a 4000h read or write it could capture the DFILE address and then could listen for reads/writes from/to those memory spaces and build up a picture of the display. And then using a lookup table for the characters, output them via a suitable VGA/TV object.
This process could be sync'd to the NMI display routines.
Thoughts?
I propose that a Prop monitors A15, /M1 and D6 (at the expansion connector ) and reads the data on D0 - D7 (at the expansion connector ) when A15, /M1 and D6=0 . This may need to be followed by a second read to ensure data has settled.
The display file starts with a $118 and each line contains the the display character codes and ends with a $118. The display file ends with a $118(?).
It would be easy to copy the ZX81 character table to the Prop and build the display from there.
Cheers
Of course you would have to read D0 thru D7 to get the character that was being displayed.
And remember that each line is displayed 8 times.
The timing might get tricky because you don't know when a new screen is starting, but there is probably enough time in the top and bottom blank lines to detect that.
So I see it as:
1) wait until A15 is low for xxx uSec [ZX81 is producing bottom blank lines, vsync, and top blank lines no memory access]
2) wait until A15 is high, M1 is low and D0-7 = $118 (the beginning halt instruction of video frame)
3) now each character is output on D0-D7 when A15 is high and M1 goes low, each video line ends with a $118 and each character line is repeated 8 times
4) after 24 character lines go back to step 1
I have a couple ZX81s around, but I would have to find an edge connector to hook up to them.
Bean
Will the following help?
This is when I think the Prop needs to capture the data bus. Syncing to the Z80 to the T2 time would be based on the values of A15 and /M1 as described in my previous post.
This is how the ZX81ULA generates the video signal
Prop can test this bit and invert character data for inverse character generation.
Thus we continue sampling based on the A15, /M1 and D6 values until D6=1 which signals the end of a line and ultimately the end of the video field.
This is the way the ZX81 executes the ZXBasic program
I could be way off but by reading D6 during the opcode fetch above 32K would this provide the screen sync albeit at the end if the display period.
I really wish I had kept my ZX81's now.
EDIT: Tidied up formatting so post is more readable
I been new here, and read this Thread with most Interrest.
I'm a great Propeller Fan and make some Work...
Maybe i can help blittled
Here is my Work:
http://zx81vga.ws-nbg.de
Greetings from Germany, Nuremberg
P.S.
Sorry for my bad English
Welcome to the forums!
Thank you for the awesome link!
I think there are a bunch of people around here that will find it very useful.
I look forward to reading through the documentation.
Many thanks
Great project btw!
