soldering
L_Gaminde
has anyone here used solder pots for soldering circuit boards I have about 150 boards and no solder mask does it matter if there's no soldermask? any hints on using one are they worth it
How big are the boards?
A solder pot such as these should work without solder mask if you do not immerse the board in solder, but just contact the bottom of the board..
Flux in liquid form is not expensive. I see liter bottles of it at the local shop, and is washes up with plain water.
http://www.icmfluxes.com/chemicals-printed-circuit-boards.html
The OP did not say if Lead or Non-Lead is involved. That could make a difference.
Rosin flux residue, when used in solder pot or wave soldering situations, is not much of a concern. It is pretty much dissipated by the large amount of solder being applied.
That's not to say a cleaning with Isopropyl would be advised anyway.
