Really LOUSY paint.
NWCCTV
Recently I decided my office needed a serious make over so I could have more room to work on my projects and still be able to operate my business. Since my office/shop space has not been painted in about ten years I decided I would I would paint. Over the years I have done my fair share of painting. I have normally used Olympic paint and have never had any issues. This time however I decided to go with all the hype and use Valspar. HUGE mistake. On walls that already have primer paint and one coat of semi gloss, I am now on my fourth coat just trying to get complete coverage. I have lightly textured walls and I am using a roller that is made for it and even says one coat. I can not blame the roller though as I am sure it is the paint. I emailed Valspar and now they want me to waste my time calling them. It's a bit late for that!!!! I figured two coats would have done it but boy was I wrong.
The new paint with built-in primer probably would do it in two coats and the extra $10/gallon may be worth it vs labor/time cost.
I never paint with semi-gloss (only for baseboard) I don't even use satin, sounds nice but is to shiny
Eggshell is the highest level of gloss I go, and I prefer to use flat-enamel that is between flat and eggshell.
It is important to buy from a quality producer that has outlets that have a rapid inventory turnover. Paint has a shelf-life that causes the pigment to settle, thus the big shakers used in paint stores. But paint also has emulsifiers that make the paint easier to apply and to cover better. Cheaper paints and off brands skimp on the additives. They also sell to outlets that don't have the turnover that assures the paint pigment is not settled in the bottom of the can.
I generally found either Glidden or Fuller to be excellent choices.
Stirring for 20 minutes might not work if you don't actually dig into and scrape the settled pigment off the bottom of a can. You have to get everything off the bottom and into suspension.
Did you use a wooden paint stirrer or a power stirrer?
I have found a stick just doesn't cut it in a 5 gallon bucket.
Yes they do, I'm not sure if all or any HomeDepot/Lowes have them or if plastic buckets are not recommended but its a Homer bucket in the pics.
http://www.ebay.com/itm/Red-Devil-5305-5-1-Gal-Paint-Shaker-with-1-Year-warranty-/281158049743#ht_2827wt_1399
I have seen then at Porter Paint, Benjamin Moore, and Sherwin-Williams shops; but they deal with a lot of contractors.
I worked in a drugstore when I was in high school. They sold paint and had a one-gallon-sized shaker. I guess you're not supposed to shake aluminum paint. Well, someone did. The mess was awesome.
We had a big economic downturn, to there has likely been a lot of inventories that have not turned over within reasonable time. But if you get stuck with old paint, get everything off the bottom of the can and into suspension and you have a good change it will work well.
