32312 micro sd card adapter — Parallax Forums
RS_JimRS_Jim Posts: 1,777
edited 2013-09-06 06:08 in General Discussion
I asked this question at parallax.com and got no answer so I will ask it here. Is this module compatible with SDHC cards or only SD? I have an available 8 gb sdhc card I could use otherwise I need to find a 2g or less.
Jim
    edited 2013-09-05 11:32
    The adapter works with both SDHC and SD cards. The "special sauce" is in the software. Kwabena's driver (here) should work. Older drivers like the various FAT16 ones will not.
    edited 2013-09-05 16:34
    I've used Kye's driver with a couple of different 8GB uSD cards.
    A couple of the cards I used had to be reformatted (the slow way) before they would work with Kye's driver. Apparently the driver checks for errors that are relatively common on SD cards (at least they seem to be common on my SD cards). If the driver finds an error, it won't mount the card.
  • RS_JimRS_Jim Posts: 1,777
    Thanks!
    Jim
