32312 micro sd card adapter
I asked this question at parallax.com and got no answer so I will ask it here. Is this module compatible with SDHC cards or only SD? I have an available 8 gb sdhc card I could use otherwise I need to find a 2g or less.
Jim
Jim
A couple of the cards I used had to be reformatted (the slow way) before they would work with Kye's driver. Apparently the driver checks for errors that are relatively common on SD cards (at least they seem to be common on my SD cards). If the driver finds an error, it won't mount the card.
Jim
