To a large extent, the onus is on PropBasic fans/programmers to make this compiler more popular. Spin is so convenient due to the OBEX. We need a LOT more PropBasic contributions.
I need to create an array dynamically during runtime, i.e. the dimension of the array is the result of a calculation, but I can't do that with "Hub_Array HUB WORD(Calculated_Variable)". However, addressing the Hub Ram directly is not a problem. So, instead of using an Array definition, I can write to and read from a range of addresses in the Hub Ram suitable for the size of the array I need, using a "base" address and offsets for each Array value. But the question is which part of the Hub Ram is safe to use without overwriting program code (most of my programs use LMM mode) or Hub Variables?
I have been "poking" (who still remembers this Basic command?) around in the Hub Ram and it seems that program code and variables are loaded starting from address $0000 upwards. The propeller Datasheet says the following regarding Cog Ram: "When a cog is booted up, locations 0 ($000) through 495 ($1EF) are loaded sequentially from Main RAM / ROM .....", so I guess the Hub Ram is addressed in the same fashion?
Which means, depending of the size of the LMM program + Variables, it should be safe to to use addresses at the upper end ($7FFF) of the Hub Ram?
I forgot to mention regarding the question in my previous post: for those who need multi-dimensional arrays, I have developed a rather simple method of "storing" a multi-dimensional array as a single array. I have attached sample code for 2, 3 and 4-dimensional arrays as well as a spreadsheet that shows the math. As soon as I get the dynamic array code sorted, I'll post new sample programs.
Regards
Andre
PS. I have modified the original TX_RX Library for generic SEROUT & SERIN usage so if you want to run my sample programs as is, you will need to use the attached TX_RX_LIB
I don't know if you are still working on PropBasic - there has been no posts for a while? Is there a new thread?
In any case, I have come across something which worked prior to version 1.30, but does not seem to work anymore. It used to be possible to start a cog from within a task, but with version 1.30, for the sample code below, Task_2.spin generates an error (compiling with Viewport). Same problem if you try starting from Task_1.
Any suggestions?
Regards
Andre
Sample code:
DEVICE P8X32A, XTAL1, PLL16X
XIN5_000_000Task_1 TASK
Task_2 TASK
PROGRAM START
START:
COGSTART Task_2ENDTASK Task_1ENDENDTASKTASK Task_2COGSTART Task_1 ' <- This generates a compiler error
ENDENDTASK
Mickster
This is true. I just uploaded a Keyboard library http://obex.parallax.com/object/709 but many many more are needed.
The ones I get the most requests for are SD Card and Floating Point Math if anyone wants to tackle either of those I'd be willing to help.
Bean
Regards
Andre
Regards
Andre
Bean
Any suggestions?
Regards
Andre
Sample code:
DEVICE P8X32A, XTAL1, PLL16X XIN 5_000_000 Task_1 TASK Task_2 TASK PROGRAM START START: COGSTART Task_2 END TASK Task_1 END ENDTASK TASK Task_2 COGSTART Task_1 ' <- This generates a compiler error END ENDTASK
You might be able to pass the TASK address via a HUB variable.
Try this:
DEVICE P8X32A, XTAL1, PLL16X XIN 5_000_000 Task_1 TASK Task_2 TASK temp VAR LONG Task1Addr HUB LONG PROGRAM START START: \mov temp,Task_1_COG ' Task name with "_COG" appended WRLONG task1Addr,temp COGSTART Task_2 END TASK Task_1 ENDTASK TASK Task_2 temp_COG VAR LONG RDLONG task1Addr,temp_COG COGSTART temp ' NOTE: leave off the _COG ending ENDTASK
Bean
Thanks, it works like a charm!
A.
Bean has announced some update work to the codebase here:
http://forums.parallax.com/discussion/166954/propbasic-update-june-2017
Please check that thread if you'd like to suggest anything toward the new release!
