No Basic Stamp found!
My USB Basic Stamp Homework Board is recognized with Run, Identify; but when I attempt to run code, I get the message "No Basic Stamp found".
I have reset the latency timer to 1 under device manager for the COM port, with seemingly no impact.
I have used BoeBots with the standard BS2 Board with no problems, only these Homework Boards are giving me problems. I am running Windows 7 Pro, if that makes a difference.
Please help before this gets more discouraging!
Try uninstalling the drivers, then reinstall BEFORE plugging in the USB adapter.
Having just bought a class set of 25 of these "What's a Microcontroller" kits, I am a little concerned that fresh batteries will not last for the duration of exercises in the book for all students. I will test to see if this battery lasts for the duration. Thank you, again. Sincerely appreciated.
You're much better off using an AC supply like the 7.5V 1A ones that Parallax (or RadioShack) sells. You'll need to make an adapter for the battery clips or even permanently solder the wires from the AC adapter to the clips on the board (after cutting off the plug it comes with and stripping and tinning the ends of the wires that went to the plug). Make sure it's connected properly since getting the connections backwards can damage the HomeWork Board.
