Disabling Reset Button, PropStick USB
G'day,
Need to disable the reset button of a propstick USB without desoldering the button. To do this, would a decent approach be to solder the RESn pin of the propstick up to 3.3v?
John
John
Bean
Thanks for this. Unfortunatly this is out of the question - any other suggestions? The problem is I have a circuit board just above the reset pin, and although the chances of it pressing it are minimal, I'd rather not take chances. I'll figure out a "mechanical" way to solve this problem.
Thanks!
-John
By far the best way to handle this is to remove the reset button. Not sure why you can't do that ?
If you can't for some reason desolder it, you may be able to cut it off.
Bean
I'm probably able, it's more of a case of not wanting to! It's a minor issue, I was just wondering if there was a quick fix that I could easily solder in, as there is not, what I'm thining of doing is putting a small rectangular brace of antistatic foam around the button, this will take 2 minutes to make, and will prevent things from pressing the button.
Thanks again for the help!
-John
Bean
Yeah, got that the first time, it's just that I don't want to cut off the button, might want it in the future! Thanks again for all your help though!
-John
I usually stick a jumper link (and another pull-up)in there, on my homemade stuff.
