Parallax Education Propeller C SimpleIDE Updated — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2013-08-18 19:05 in Propeller 1
Hi All,
We are getting very close to an official release for fall semester.
The latest SimpleIDE distribution packages have been posted.
Please find them here: Linux MacOSX Windows
Linux binary varietal packages will follow.
SimpleIDE and PropellerGCC can be built from sources.
If there are any troubles, please let me know.
Distributions include the P8x32a PropellerGCC release_1_0_0_n.
SimpleIDE Propeller 2 support will follow when required.
An updated user-guide can be found in the packages.
It is also attached here for convenience.
  • Ken GraceyKen Gracey Posts: 7,418
    edited 2013-08-12 09:31
    Yeah! Just in time for the Fall semester.
    edited 2013-08-12 09:47
    Loaded fine, Windows 7 64 Bit.
    Will take it for a test drive later.
    Good work Steve and crew!
    edited 2013-08-12 11:21
    We switched to this version (plus the updated Learn folder zip) for the "First C" podcasts starting with the one that will release tomorrow.
    Everything seemed to work just fine for us, thanks.
    edited 2013-08-12 12:35
    SimpleIDE v0.9.40 (The propside branch) builds and runs fine here on 64 bit Debian Wheezy. Looking good.
  • jazzedjazzed Posts: 11,803
    edited 2013-08-12 13:31
    Heater. wrote: »
    Good to hear.
    The actual branch name is "spinside" though for new build adventurers. propside is the googlecode name.
    edited 2013-08-12 16:22
    User Guide very good to read ...
    one mistake in Simple IDE Terminal / Options / Function
    wrong labeling on character 13 and character 10 (switched)
    character 13 is CR
    character 10 is LF / New Line
    [Edit]
    It is just wrong in the PDF. (old Image)
    The actual installed Version does it correct.
    Installed without problem on Windows Ate (my computer) Test-Machine...
    [/Edit]
    Enjoy!
    edited 2013-08-12 17:04
    Oops, yes, it's the "spinside" branch of the "propside" repo. I'm tired.
    edited 2013-08-12 20:09
    There is one notable feature enhancement not mentioned in the user guide.
    Compiling CMM/LMM programs will now create a Propeller .binary that can be loaded by others.
    edited 2013-08-12 21:06
    SimpleIDE for Linux is posted here.
    It is a 32bit package that should run on Debian, Fedora, Mint, and Ubuntu.
    Other variations will be posted later.
    @msrobots, thanks for the note. Dave Hein noticed the LF/CR issue a few weeks ago and mentioned it.
  • max72max72 Posts: 1,155
    edited 2013-08-13 08:08
    Not sure if it is the right place to post it... but for sure is the most up to date discussion, so I guess it would work.
    I apologize for being so late, but please find attached a first review of the Italian translation.
    Some of the key words have not been translated because I have not been able to find a decent equivalent.
    I left some of the terms with accelerators in English, with IT translation on the side. It could be tweaked, but I have not experience with that, so I preferred to stay conservative.
    Moreover I have not been able to test it on SimpleIDE, and I'm sure a review is mandatory..
    Massimo
    edited 2013-08-13 10:15
    max72 wrote: »
    Massimo
    Thanks Massimo.
    You can test this if you create a .qm file using QtLinguist, rename it as simpleide_it.qm, and put it into the Program Files\SimpleIDE\translations folder.
    edited 2013-08-13 12:37
    Thanks for the tip!
    Massimo
    edited 2013-08-13 23:58
    Ok,
    I created the .qm file, but I cannot make SimpleIDE load the language file (neither mine neither the ones already in the SimpleIDE installer).
    What am I doing wrong?
    Massimo
  • RoadsterRoadster Posts: 209
    I have tested SimpleIDE with Windows7, Linux Mint Mate, and Mac Mountain Lion, and have no issues to report
