Parallax Education Propeller C SimpleIDE Updated
Hi All,
We are getting very close to an official release for fall semester.
The latest SimpleIDE distribution packages have been posted.
Please find them here: Linux MacOSX Windows
Linux binary varietal packages will follow.
SimpleIDE and PropellerGCC can be built from sources.
If there are any troubles, please let me know.
Distributions include the P8x32a PropellerGCC release_1_0_0_n.
SimpleIDE Propeller 2 support will follow when required.
An updated user-guide can be found in the packages.
It is also attached here for convenience.
Will take it for a test drive later.
Good work Steve and crew!
Everything seemed to work just fine for us, thanks.
Good to hear.
The actual branch name is "spinside" though for new build adventurers. propside is the googlecode name.
one mistake in Simple IDE Terminal / Options / Function
wrong labeling on character 13 and character 10 (switched)
character 13 is CR
character 10 is LF / New Line
[Edit]
It is just wrong in the PDF. (old Image)
The actual installed Version does it correct.
Installed without problem on Windows Ate (my computer) Test-Machine...
[/Edit]
Enjoy!
Compiling CMM/LMM programs will now create a Propeller .binary that can be loaded by others.
It is a 32bit package that should run on Debian, Fedora, Mint, and Ubuntu.
Other variations will be posted later.
@msrobots, thanks for the note. Dave Hein noticed the LF/CR issue a few weeks ago and mentioned it.
I apologize for being so late, but please find attached a first review of the Italian translation.
Some of the key words have not been translated because I have not been able to find a decent equivalent.
I left some of the terms with accelerators in English, with IT translation on the side. It could be tweaked, but I have not experience with that, so I preferred to stay conservative.
Moreover I have not been able to test it on SimpleIDE, and I'm sure a review is mandatory..
Massimo
Thanks Massimo.
You can test this if you create a .qm file using QtLinguist, rename it as simpleide_it.qm, and put it into the Program Files\SimpleIDE\translations folder.
Massimo
I created the .qm file, but I cannot make SimpleIDE load the language file (neither mine neither the ones already in the SimpleIDE installer).
What am I doing wrong?
Massimo
