Drawbot using eBay stepper motors, the Little Robot Wheels, and PropForth (Video) — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2014-08-22 09:19 in Robotics
This project is my wireless drawing robot which uses PropForth and Nicholas G. Lordi's Robot Control Language. The robot is controlled wirelessly via Pololu Wixels, and because it uses FORTH is fully remotely programmable. Here's the bill of materials:
1   small sheet 1/4 Hobby plywood  ($3)
2   eBay steppers                  ($5)
2   Wheels from Propeller Powered  ($4)
6   Parallax L mounting brackets   ($2)
1   1.25" caster (sorry Tommy)     ($1)
10  1" Parallax standoffs          ($1)
1   standard Servo                 ($12)
2   Pololu Wixels for wireless serial ($20)
1   Propeller Platform                ($37)
1   Wulfden Robot Control Board    ($14)
1   Medium sized breadboard        ($4)
2   3 AA battery holders           ($6)
1  small piece of brass tubing     ($1)
1  paperclip
?  4-40 nuts and bolts
I had the Propeller Platform and Robot Control Board laying around from a dismantled project, so I repurposed them here. A quick start board and a little bit of breadboard work could save a fair bit of the budget. The two hardest parts of the project were cutting and drilling the plywood which took an afternoon, and the FORTH programming which has been several two hour sessions so far. Here are some pictures:
Between the transmitter, the motors, and the pen lifting servo this thing eats batteries. I generally get a couple of hours debugging per charge, so progress per day is limited. I'm nearly done with my demo program which has taken a fair bit of time because this is my first robot FORTH project. However, the ability of FORTH to act as a command interpreter coupled with wireless programming is really powerful. Here's my current source code which could use some better comments.
\ Before loading this program load PropForth servo library (change to cog 0, and Nicholas G. Lordi's Robot Control Language
\ start the drawbot by initializing the servo library and the robot command language. The 0 GF halts the robot.
: start_drawbot
    sm_start_servos START 0 GF ;
\ pen up using servo on pin 0
\ The hex magic number is the servo pulse width determined
\ by trial and error
: PU
    0 h15E0 sm_setpos 500 delms ;
\ pen down using servo on pin 0
\ Again, the hex constant was determined experimentally.
: PD
    0 hCE4 sm_setpos 500 delms ;
\ A set of draw moves.
\ Move without drawing 2 forward.
: SPACE
  PU 2 GF ;
\ Draw a line 4 long
: STROKE
  PD 4 GF ;
\ Draw a line 2 long
: DASH
  PD 2 GF ;
\ Go down one line and back to the start of the row.
: CRLF
  PU 90 GC 6 GF 90 GC 30 GF 180 GC ;
\ Draw a letter H
: H
  90 GCC
  STROKE
  PU 2 GB
  90 GC
  DASH
  PU 90 GCC 2 GF 180 GCC
  STROKE
  PU 90 GCC
  SPACE ;
\ Draw a letter E
: E
  90 GCC
  STROKE
  PU 90 GC
  PD 3 GF
  PU 3 GB 90 GC
  2 GF 90 GCC
  DASH
  PU 2 GB 90 GC
  2 GF 90 GCC
  PD 3 GF
  SPACE ;
\ An L
: L
  90 GCC
  STROKE
  PU 4 GB 90 GC
  PD 3 GF
  SPACE ;
\ and an O
: O
  90 GCC
  STROKE
  90 GC 3 GF 90 GC
  STROKE
  PU 90 GCC 3 GB
  PD 3 GF
  SPACE ;
: W
 90 GCC
 STROKE
 PU 4 GB
 45 GC
 DASH
 90 GC
 DASH
 135 GCC
 STROKE
 PU 4 GB
 90 GC
 SPACE ;
: R
  90 GCC
  STROKE
  90 GC
  DASH
  30 GC
  DASH
  60 GC
  1 GF
  30 GC
  DASH
  60 GC
  DASH
  180 GC
  DASH
  30 GC
: D
  90 GCC
  STROKE
  90 GC
  DASH
  30 GC
  DASH
  60 GC
  1 GF
  30 GC
  DASH
  60 GC
  DASH
  PU 180 GC
  SPACE SPACE ;
\ Draw the word HELLO
: HELLO H E L L O ;
\ Draw the word WORLD
: WORLD W O R L D ;
\ Yes, it's HELLO WORLD in FORTH
: HELLO_WORLD HELLO CRLF WORLD ;
    edited 2013-08-12 07:56
    That's pretty cool. Its only a few buck more than LittleRobot, but looks nicer, and can draw. I want to try this but my wife always freaks out when the kids and I use sharpies on her kitchen table. :)
    How do you like Nick's robot control language? I haven't tried it yet, it is the way to go?
    One thing that might help with battery use 4 AA NiMH instead of 3 AA alkaline -
    We used a 4 AA battery holder, but Alkaline batteries being 1.5v meant we we over the five volt limit of some of the parts. Rather than getting a regulator, I tried 3 AA and a dummy (1-3/4" machine bolt). This worked fine, but only lasted a couple hours, as you have found.
    Next we tried 4 AA NiMH cells. At 1.2v, four cells is delivers 4.8v, below the five volt limit for the parts. I have charged the first set twice since April, and the second set once, when I bought them in July. While I do most of my development powered by USB connected to the computer, I have been able to do demos and non tethered tests almost every day. So I think 4 AA NiHM last several times longer then 3 AA alkaline in this application.
    edited 2013-08-12 08:06
    Nice bot Martin.
    You know erco will demand a video of it drawing a figure 8. :)
    edited 2013-08-12 10:05
    Great work Martin. :thumb::thumb: Your woodworking skills have come a long way. Sharp blades for sharp work...:smile:
    No need to apologize.
    At least, if for only a moment, you did consider the idea.:smile: I know it can be an exceptional expense to a low budget machine.
    I just spent $30 bucks on a servo, + $5 on the 'axle assembly' parts, and roughly $5 for a tire. Just to avoid using a caster...:lol:
    Anyway, thanks for sharing. And can't wait to see 'the eight'...
    -Tommy
    edited 2013-08-12 11:23
    @All, thanks for the kudos, and a video should be posted soon.
    I've been about nervous about that too. One errant turn command coupled with a pen down and I'm in hot water! I've done most of my testing without a pen in the pen holder, then put one in when I'm reasonably sure a particular move sequence is working.
    I really liked it once I figured it out and calibrated it. It’s easy to use for straight moves and angular rotations. I haven’t figured out arcs yet, but that looks possible with different speeds to each wheel. BTW I’m using two 3 AA battery holders for a total of 7.2 volts. I’m running everything off my boards 5 volt regulator, so given the drop across the regulator I think it is browning out before the batteries are discharged. Normally I run motors directly off batteries, but I've been a bit hesitant to put 7.2 volts through the steppers.
    Ttailspin wrote: »
    Thanks. Good tools helped. I have a drill press and bought a Dremel circle cutting jig. I drilled a hole in the center-line and cut arcs on the ends. It made it looks spiffy compared to the squared off ends I usually use. I also used both of tools on my delta robot which will isn't as far along as this project.
    edited 2013-08-18 09:08
    I finally got some time to work all the kinks out of the robot. So here's a video:
    I made tweaks to the code by factoring out common moves. Here's the update:
    \ robot command language. The 0 GF halts the robot.
    : start_drawbot
    \ pen up using sevo on pin 0
    \ by trail and error
    : PU
        0 h15E0 sm_setpos 250 delms ;
    : PD
        0 hCE4 sm_setpos 250 delms ;
    \ Move without drawing.
    : SPACE
      PU 2 GF ;
    : BSPACE
      PU 2 GB ;
    : STROKE PD 4 GF ;
    \ Draw a line 3 long
    : EMDASH PD 3 GF ;
    : ENDASH PD 2 GF ;
    : TICK PD 1 GF ;
    \ Go Clockwise Right Angle
    : GCRA PU 90 GC ;
    \ Go Counter Clockwise Right Angle
    : GCCRA PU 90 GCC ;
    \ Go clockwse 180
    : GC180 PU 180 GC ;
    \ Go down one line andback to the start of the row.
    : CRLF
      GCRA 6 GF GCRA 24 GF 180 GC ;
    \ From here down build the letters using the primatives above as much as possible.
    : H
      GCCRA
      STROKE
      BSPACE
      GCRA
      ENDASH
      GCCRA
      SPACE
      GC180
      STROKE
      GCCRA
      SPACE ;
    : E
      GCCRA
      STROKE
      GCRA
      EMDASH
      PU 3 GB
      GCRA
      SPACE
      GCCRA
      ENDASH
      BSPACE
      GCRA
      SPACE
      GCCRA
      EMDASH
      SPACE ;
    : L
      GCCRA
      STROKE
      BSPACE BSPACE
      GCRA
      EMDASH
      SPACE ;
    : O
      GCCRA
      STROKE
      GCRA
      EMDASH
      GCRA
      STROKE
      GCRA
      EMDASH
      GC180
      SPACE SPACE SPACE ;
    : W
      GCCRA
      STROKE
      BSPACE BSPACE
      45 GC
      ENDASH
      90 GC
      ENDASH
      135 GCC
      STROKE
      BSPACE BSPACE
      GCRA
      SPACE ;
    : R
      GCCRA
      STROKE
      GCRA
      ENDASH
      30 GC
      TICK
      60 GC
      TICK
      30 GC
      TICK
      60 GC
      TICK
      GC180
      1 GF
      60 GC
      TICK
      60 GCC
      SPACE ;
    : D
      GCCRA
      STROKE
      GCRA
      ENDASH
      30 GC
      ENDASH
      60 GC
      1 GF
      30 GC
      ENDASH
      60 GC
      ENDASH
      GC180
      SPACE SPACE ;
    : HELLO H E L L O ;
    : WORLD W O R L D ;
    edited 2013-08-20 07:05
    Magnificent! Your homemade bot has the S2 shaking in its botboots! Congrats on combining multiple challenges in one new platform. The only challenge left is arcs for a figure 8! :) Great demo video, too.
    Lots of hours involved, clearly. Imagine the amazing things we forumistas could do if we join forces on one big project!
    edited 2013-08-21 06:28
    Erco, thanks for the watching the video and the kudos. I'll start working on a figure 8 shortly.
    edited 2014-07-08 14:41
    Martin_H wrote: »
    Still waiting nearly a year later, Martin_H! :)
    edited 2014-07-20 12:07
    Erco, I posted this one on the figure eight thread almost a year ago!
    edited 2014-07-22 15:20
    Sweet, I'm so behind the times. At least now you posted here to make this thread complete. :)
  • bose86bose86 Posts: 2
    edited 2014-08-22 07:51
    @Martin_H
    can you please help out.
    i can not figure out how to attach a wheel to the 28BYJ-48 motor.
    i dont have anything that fits into his head.
    can you please share a ebay link with gears,wheel that will fit 28BYJ-48 ?
    bose86, It is a 5mm D shaft, You could try this..http://www.pololu.com/product/2673 It will adapt the heck out of any wheel/gear you bolt to it.
