Logitech Extreme 3D Pro Joystick Driver, Hack, Extras
This is my initial post to really start this project I had started before. After graduating from Engineering school I have more time to devote to actual stuff, and when looking around for a project I found a giant pile of dust, under which was this joystick.
I've had this thing for years. It's a Logitech Extreme 3D Pro, and can be had for $30 bucks or so.
Amazon
I'll add more detail later, but essentially my buddy broke his and I managed to fix it, and realized how simple the design looked. I bought a new shinier joystick for gaming (Saitek) and started hacking the 3D Pro.
I took out the screws from the base, took out the circuit board that converts all the signals then sends it out a USB cable, and started figuring out how it worked. My most useful tool for this was Parallax's USB Oscilloscope.
Parallax
I found that there were fewer wires than buttons. It was accomplished by sending pulses up the wires. I managed to duplicate this system and then write it in Assembly code.
When writing down all the improvements I can make, I realized this was a large enough project to warrant a Project Thread.
Current to do list:
- Improve documentation
- Add calibration (in progress)
- PID or something to smooth the ADC data
- Make it easier to call the program externally
- Eventually use this for something cooler than controlling a cardboard box turned into an Ekranoplan
So anyway, this is just opening up the project. I don't have much on it yet, but I cleaned up my demo last night and will keep working on it.
OBEX Link
I do have an old YouTube video of an old version. I'll be making a better video in the future.
http://www.youtube.com/watch?v=XJqs5wlxxEY
This is my first project, so I'd love to have some input, especially about making this user friendly and well documented. I'll have 100 problems with this. My current one is when calibrating, sometimes the output will go over 65,536. Being a Mechanical/Aero Engineer I don't know much about WORD,LONG,FLOAT etc. So I need to figure out if I should leave a safety gap, or change the data type etc. I may as well post all the code below for now, since people tend to ask for it.
Thanks for the help and any comments/ratings. Please enjoy this object, help me make it better for you and others, and let others know if it works for you so they aren't afraid of spending $30 bucks on a dud.
{{ Keith Young - kyoung21@utk.edu Updated - Jul 31 2013 Copyright (c) 2012 Keith Young Terms of use at end of file Instructions: A basic schematic is shown below for how to get things set up. Several examples are given for how buttons and analog signals can be used. For now, the default I'm uploading is with the 6 base buttons on the joystick commented out to improve the speed. This is because it's difficult to fit all the wires without modifying the joystick through drilling or getting special wires. It's totally easy and doable to make more space for the wires, but the assumption is you don't want to do any more than remove the circuit board inside and replace all that with wires going out to your Prop. To enable these 6 buttons, go to the assembly code below and uncomment all the code for the extra buttons. I have several improvements in mind, but first I want to see how this better demo does. I hope to get better documentation, calibration, and smoothing etc in later versions. I am new to uploading this sort of stuff, so please leave feedback for recommendations, and especially let people know if this works for you. I don't want people to be afraid of spending $30 bucks to get the joystick and fear this won't work. So please comment and rate! This assumes colors of wires are the same throughout the manufacturing history of this product. You may wish to check this so as to be sure you aren't connecting this bass ackwards. Joystick ----------------------------------------------------------------- Red ┼ Pin 19 and Pull Up 3.3V (I use 10Kohm) Green ┼ Pin 20 and Pull Up 3.3V White ┼ Pin 21 Yellow ┼ Pin 22 and Pull Up 3.3V Pink ┼ Pin 23 and Pull Up 3.3V Orange ┼ Pin 24 Grey ┼ Pin 25 Brown ┼ 3.3V Rudder Pot Black ┼ 1st Channel ADC Blue ┼ GND Red ┼ 3.3V Aileron Pot Green ┼ 2nd Channel ADC Elevator Pot White ┼ 3rd Channel ADC Black ┼ GND Joystick Base ------------------------------------------------------------ Orange ┼ Pin 15 Black ┼ Pin 14 and Pull Up 3.3V Brown ┼ Pin 13 and Pull Up 3.3V Grey ┼ Pin 12 and Pull Up 3.3V Pink ┼ Pin 11 and Pull Up 3.3V Yellow ┼ Pin 10 White ┼ GND Throttle Pot Green ┼ 4rth Channel ADC Red ┼ 3.3V tk Basic ADC Schematic tk link to website/blog tk Calibration tk PID or other smoothing tk Easier to call the program from outside http://www.amazon.com/Logitech-Extreme-Joystick-Silver-Black/dp/B00009OY9U/ https://www.youtube.com/watch?v=kAVJzw98xW4 (Old version not using PST) Also note, skipping the base buttons you can fit the silver cover back on without problems. When you want to include the 6 base buttons though you'll probably need to drill a small hole or something to fit all those wires out since the USB wire hole is too small. }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ADC_dpin = 1 'Sets ADC Pins ADC_cpin = 2 ADC_spin = 0 rudderc = 0 'Sets ADC Channels aileronc = 1 elevatorc = 2 throttlec = 3 baud = 115200 OBJ AD : "MCP3208_fast_ADC" DB : "FullDuplexSerial" VAR long Shared word rudder, aileron, elevator, throttle 'Calibration word ruddermin, ruddermax, aileronmin, aileronmax word elevatormin, elevatormax, throttlemin, throttlemax word rudderslope, rudderint word aileronslope, aileronint word elevatorslope, elevatorint word throttleslope, throttleint word rudderout, aileronout, elevatorout, throttleout long stack[256] byte Cog PUB Start(Pos) : Pass AD.Start(ADC_dpin, ADC_cpin, ADC_spin, 0) 'Start ADC DB.Start( 31, 30, 0, baud) 'Start Parallax Serial Terminal communication Pass := (Cog := cognew(@entry, @Shared)+1)>0'Begin running Assembly code 'It's where the actual sampling takes place dira[27]~~ 'LED setup outa[27]~ dira[26]~~ outa[26]~ Check 'Enter main loop Pub Check repeat 'Main user accessable loop waitcnt(clkfreq / 20 + cnt) 'Slow down long enough to display on PST rudder := AD.In(rudderc) 'Get ADC value of Rudder aileron := AD.In(aileronc) 'Get ADC value of Aileron elevator := AD.In(elevatorc) 'Get ADC value of Elevator throttle := AD.In(throttlec) 'Get ADC value of Throttle DB.Str(String(16)) DB.Str(String("Buttons = ")) DB.Dec(Shared) 'Display status of Buttons DB.Str(String(13)) DB.Str(String("Rudder = ")) rudderout := rudderslope*rudder-rudderint DB.Dec(rudderout) 'Display Rudder value DB.Str(String(13)) DB.Str(String("Aileron = ")) aileronout := aileronslope*aileron-aileronint DB.Dec(aileronout) 'Display Aileron value DB.Str(String(13)) DB.Str(String("Elevator = ")) elevatorout := elevatorslope*elevator-elevatorint DB.Dec(elevatorout) 'Display Elevator value DB.Str(String(13)) DB.Str(String("Throttle = ")) throttleout := throttleslope*throttle-throttleint DB.Dec(throttleout) 'Display Throttle value DB.Str(String(13)) {{ The small section immediately below shows how the buttons can be used in your code. 1 - If you pull the trigger, PST will show "Trigger Engaged", LED on 2 - If you press HAT forward right, PST will show "Combo Engaged", LED on 3 - If you press buttons 3 and 4 on Joystick, calibrate 4 - If throttle is high and button 2 is held... }} '1 if shared & butt1 == butt1 outa[27]~~ DB.Str(String("Trigger Engaged")) else outa[27]~ '2 if shared & butt13 == butt13 and shared & butt14 == butt14 outa[26]~~ DB.Str(String("Combo Engaged")) else outa[26]~ '3 if shared & butt3 == butt3 and shared & butt4 == butt4 DB.Str(String("Calibrate")) Calibrate '4 if shared & butt2 == butt2 and throttle > 2000 DB.Str(String("AFTERBURNER")) Pub Calibrate waitcnt(clkfreq + cnt) ruddermin := rudder ruddermax := rudder aileronmin := aileron aileronmax := aileron elevatormin := elevator elevatormax := elevator throttlemin := throttle throttlemax := throttle repeat while shared & butt3 <> butt3 and shared & butt4 <> butt4 waitcnt(clkfreq / 50 + cnt) 'Slow down long enough to display on PST rudder := AD.In(rudderc) 'Get ADC value of Rudder aileron := AD.In(aileronc) 'Get ADC value of Aileron elevator := AD.In(elevatorc) 'Get ADC value of Elevator throttle := AD.In(throttlec) 'Get ADC value of Throttle if rudder < ruddermin ruddermin := rudder if rudder > ruddermax ruddermax := rudder if aileron < aileronmin aileronmin := aileron if aileron > aileronmax aileronmax := aileron if elevator < elevatormin elevatormin := elevator if elevator > elevatormax elevatormax := elevator if throttle < throttlemin throttlemin := throttle if throttle > throttlemax throttlemax := throttle rudderslope := 65536/(ruddermax-ruddermin) rudderint := rudderslope*ruddermin aileronslope := 65536/(aileronmax-aileronmin) aileronint := aileronslope*aileronmin elevatorslope := 65536/(elevatormax-elevatormin) elevatorint := elevatorslope*elevatormin throttleslope := 65536/(throttlemax-throttlemin) throttleint := throttleslope*throttlemin waitcnt(clkfreq + cnt) Pub Stop if Cog CogStop(Cog~ -1) DAT ORG 0 entry mov Mem, PAR or dira,pinn21 or outa,pinn21 or dira,pinn25 or outa,pinn25 or dira,pinn24 or outa,pinn24 {{ or dira,pinn10 Un comment this area in order to use or outa,pinn10 the 6 buttons on the base of the or dira,pinn15 joystick and the throttle or outa,pinn15 or dira,pinn17 ALL AREAS OF CODE COMMENTED OUT BELOW CONTROL and outa,pinn17 JOYSTICK BASE. UNCOMMENT FOR THIS FUNCTION }} or dira,pinn27 and outa,pinn27 xor outa,pinn21 xor outa,pinn25 xor outa,pinn24 'xor outa,pinn10 'xor outa,pinn15 mov time,cnt 'Current clock loaded into time add time,delay 'delay added to time :Loop xor outa, pinn21 'Pin 21 PHASE 1 waitcnt time,delay mov temp, ina test temp, pinn23 wz '13 Hat Up if_z or button, butt13 if_nz andn button, butt13 test temp, pinn22 wz '14 Hat Right if_z or button, butt14 if_nz andn button, butt14 test temp, pinn19 wz '15 Hat Down if_z or button, butt15 if_nz andn button, butt15 test temp, pinn20 wz '16 Hat Left if_z or button, butt16 if_nz andn button, butt16 xor outa, pinn21 '-------------------------------------------------------------------- xor outa, pinn25 'Pin 25 PHASE 2 waitcnt time,delay mov temp, ina test temp, pinn20 wz '1 Trigger if_z or button, butt1 if_nz andn button, butt1 test temp, pinn19 wz '2 Secondary if_z or button, butt2 if_nz andn button, butt2 test temp, pinn22 wz '3 Bottom Left if_z or button, butt3 if_nz andn button, butt3 test temp, pinn23 wz '4 Bottom Right if_z or button, butt4 if_nz andn button, butt4 xor outa, pinn25 '---------------------------------------------------------------------------------- xor outa, pinn24 'Pin 24 PHASE 3 waitcnt time,delay mov temp, ina test temp, pinn20 wz '5 Top Left if_z or button, butt5 if_nz andn button, butt5 test temp, pinn19 wz '6 Top Right if_z or button, butt6 if_nz andn button, butt6 xor outa, pinn24 '------------------------------------------------------------------------------------- {{ xor outa, pinn10 'Pin 10 PHASE 4 waitcnt time,delay mov temp, ina test temp, pinn12 wz '7 Base Top Left if_z or button, butt7 if_nz andn button, butt7 test temp, pinn11 wz '8 Base Top Right if_z or button, butt8 if_nz andn button, butt8 xor outa, pinn10 '------------------------------------------------------------------------------------ xor outa, pinn15 'Pin 15 PHASE 5 waitcnt time,delay mov temp, ina test temp, pinn13 wz '9 Base Middle Left if_z or button, butt9 if_nz andn button, butt9 test temp, pinn14 wz '10 Base Middle Right if_z or button, butt10 if_nz andn button, butt10 test temp, pinn12 wz '11 Base Bottom Left if_z or button, butt11 if_nz andn button, butt11 test temp, pinn11 wz '12 Base Bottom Right if_z or button, butt12 if_nz andn button, butt12 xor outa, pinn15 }} wrlong button, Mem jmp #:Loop ' Check trigger again using :loop button byte 0000000000000 delay long 5000 pinn21 long |< 21 'pinn10 long |< 10 pinn25 long |< 25 pinn24 long |< 24 'pinn15 long |< 15 'pinn17 long |< 17 pinn27 long |< 27 pinn20 long |< 20 pinn19 long |< 19 pinn22 long |< 22 pinn23 long |< 23 'pinn12 long |< 12 'pinn11 long |< 11 'pinn13 long |< 13 'pinn14 long |< 14 butt1 long |< 0 butt2 long |< 1 butt3 long |< 2 butt4 long |< 3 butt5 long |< 4 butt6 long |< 5 ' butt7 long |< 6 ' butt8 long |< 7 ' butt9 long |< 8 ' butt10 long |< 9 ' butt11 long |< 10 ' butt12 long |< 11 butt13 long |< 12 butt14 long |< 13 butt15 long |< 14 butt16 long |< 15 temp long 0 time Res 1 Mem Res 1 {{ Obviously this is the license and not part of the base buttons. Leave this commented out. /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // TERMS OF USE: MIT License /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation // files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, // modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the // Software is furnished to do so, subject to the following conditions: // // The above copyright notice and this permission notice shall be included in all copies or substantial portions of the // Software. // // THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE // WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR // COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, // ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// }}
I will also be writing about this on my website at http://www.consultkeithyoung.com/content/projects/joystick.
Let me know if this is a horrible idea. I may have stepped foot in a computer science building, but not much rubbed off on me.
free and the program in the computer is simple. I have made a Propeller object to read in the data. I have yet to take mine apart. I will be following your project. Have fun with your project!
I can definately make use of that in other projects. This project will still be necessary for me though since I need to not rely on a computer.
An update, when changing to 12 bit, the slope of my calibration curve is 1.5 so I'm having hassles. I'm looking in to F32, or another way around it since Spin seems to struggle with FLOAT variables.
This might be applicable to your project as far as fitting the range within a binary weighted value ...
http://forums.parallax.com/showthread.php/149231-DEMO-Succesive-Aproximation-Normalization-%28SAN%29-Filter
Thanks!
