The motor shield I am using with my Adruino UNO pretty much uses all the pins on the UNO. How do I connect the Parallax ping sensor? Thanks for any advice.
Welcome to the forums.
Since this is a Parallax forum, we don't usually, keep Arduino data sheets around.
If you could provide links the the Arduino Board and Motor Shield, that would help a lot.
As Publison said, we'd be glad to try and help if you could provide the information about the Arduino boards you have, since we would not have that information.
In the mean time, check out http://learn.parallax.com/KickStart/28015, for some PING to Arduino interfaces.
