Using a ping sensor with a motor shield — Parallax Forums
curarelemoncurarelemon Posts: 3
edited 2013-08-13 18:00 in Accessories
The motor shield I am using with my Adruino UNO pretty much uses all the pins on the UNO. How do I connect the Parallax ping sensor? Thanks for any advice.
    edited 2013-08-11 12:19
    Welcome to the forums.
    Since this is a Parallax forum, we don't usually, keep Arduino data sheets around.
    If you could provide links the the Arduino Board and Motor Shield, that would help a lot.
    In the mean time, check out http://learn.parallax.com/KickStart/28015, for some PING to Arduino interfaces.
  • curarelemoncurarelemon Posts: 3
    edited 2013-08-11 19:21
    Sorry. I thought there were a lot of Arduino users using this sensor, and on this forum. I'll look elsewhere.
    edited 2013-08-12 09:44
    As Publison said, we'd be glad to try and help if you could provide the information about the Arduino boards you have, since we would not have that information.
    Thanks. I found the information elsewhere.
