Propeller Mini EEPROM
I'm eager to use the Propeller Mini -- it would be ideal in a new project of mine. Just enough I/O pins.
But it's disappointing that the EEPROM is only 32k. I need non-volatile space above address $8000 to store data that will survive a program re-load.
Any simple way around this? Is there a good reason why a 64k chip isn't standard? Looks like the same package and pinout as a 32k chip, so it could fit on the existing layout - or am I missing something?
Larry
Larry
Sure. Use a 64K EEPROM. Although the loader will recognize only the lower 32K, you'll have another 32K for storing non-volatile data via one of the I2C objects in the OBEX.
The Propeller Mini is a fairly new Parallax product, so it may not be familiar. It puts a Propeller chip, two voltage regulators, xtal, and 32kB EEPROM on a 1.5 x .75 inch circuit board. Ideal for my project. Problem is that only I/O pins P0 through P18 are brought out. The others, including the clock and data pins for the EEPROM are not accessible. And I need all of the 19 available I/O lines, so -- no way to tack on an external EEPROM. And I DO need non-volatile storage above $8000.
So, am I out of luck, or what? Any other suggestions?
Larry
Are you comfortable soldering SMT devices? If so, Parallax has the 64K in stock at two bucks:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/EEPROM/List/0/SortField/4/ProductID/579/Default.aspx
If you not comfortable with the soldering job, I can do it for free. Send me the parts, and I can do a one day turnaround.
Jim
EDIT Looks like the Mini's are out of stock. Do you already have on?
EDIT: Here's a thread about one I/O expander:
http://forums.parallax.com/showthread.php/107967-mcp23017-(i2c)-example-code?highlight=Expander
I can't see more than 50 cents difference, depending on the sourcing. I think all Propeller products should be shipped with 64K IMO.
BTW, when the S2 hardware was being developed, two 32K EEPROMS were found to be less expensive than one 64K device. That was awhile ago now, so 64K pricing may have come down in the meantime.
Interesting Phil.
The 64K device that Parallax sells, (ATMEL ?), is now obsolete at Mouser, ( I have not looked for other variations). Digikey does not show a 64KX8 at 3.3v . Must do more research.
Publison:
Yes, an I/O expander is probably the only way to go. But that means two additional chips -- expander plus EEPROM. This makes the whole project less attractive, since I plan to write it up and see about publishing, for radio amateurs and other hobbyists to duplicate. Oh, well...
Also, thanks for your kind offer to modify a board. But, for the above reason, this probably wouldn't work.
There are two ways to go about it:
1. Replace the 32K chip with a 64K unit.
2. Piggyback another 32K chip, strapping one of the address lines differently.
I see where the extra chips may not work out for anything more that a one off. Since Parallax is in the process of producing more units, maybe we can convince them to put 64K devices on them, or make a new part number and charge one to two dollars extra?
You bet!! I'd be willing to pay an extra buck or so for the added EEPROM.
The seed is planted.
http://forums.parallax.com/showthread.php/149591-Please-put-a-64K-EEPROM-on-the-Propeller-MINI!?p=1200451#post1200451
http://www.microchip.com/pagehandler/en-us/products/memory/serialEEPROM/packageMap.html
Cheapest seems to be OnSemi, and the reel-level price comparison is
CAT24C512 3,000: $0.419
CAT24C256 3,000: $0.234
Which is a price premium of 0.185 for the 64KB device.
and I also think such products should include 5.0V in the regulator range. (but that is another topic)
There should be more LDOs with outputs at 4.8V, and spec'd to include USB-chargers, as well as 'any plug pack'
In the meanwhile, I'd stick a 64k EEPROM on one of my [eeZee Propeller boards if you're interested.
(https://www.tindie.com/products/bot_thoughts/eezee-propeller/)
