Low cost wireless "button/switch"
I'm fairly new to wireless stuff and I wanted to know if there is an easy way (without µC) to send the state of a button or switch 200 feet away on an open field. Does anyone have advice or clue on how I might do that? I know it could be done easily with an Xbee but I think it's over-kill just for 1 bit of unidirectional data, and then I would need to program it...
Thanks!
Thanks!
Steve
Thanks, I will take this in consideration.
That said, if you go to ebay and type "transmitter module 433MHz", you'll get lots of hits that claim 500m range (apply salt here), for a couple of bucks with free shipping from China. How can they do that?
Steve - I have to call you out on this. Parallax has awesome tech support, customer service, and the really amazing community here on the forum. Yet, I see that you have only this one post suggesting that you bought defective product. If you ask for help from Parallax or the forum, then you are quite likely to get it.
The product that Mike linked looks like a fantastic value, based on my experience designing/building a similar 433MHz encoder/decoder a few years ago. Once I burn through my inventory, I will probably convert to using these.
It runs on two coin batteries with a voltage regulator and no uController (other than the Xbee)
The Xbee although might be an overkill is reliable, very adaptable and straightforward to use. You could even use it's pin replication feature to avoid messing with API mode on the receiving side.
Just my two cents
Regards
Alex
